| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here. |
Thread Tools | Display Modes |
#13 |
Junior Member
Year: 2002
Make: Ford
Model: Ranger Off Road
Engine: 4.0 L
Class: 4X4
Used For: Daily Driver
Rep Power: 12 ![]() iTrader: (0)
I've had trouble with the rear brakes & it seems like I've seen a few other posts mentioning similar problems.
Tweet
#14 |
Year: 2003
Make: Subaru
Model: Impreza WRX
Engine: 2.0
Class: AWD
Used For: DD, showing up ricers, fun
Rep Power: 13 ![]() iTrader: (1)
From my experience with my 98:
- The 4R44E transmission (not strong enough for even mild 4 wheeling) - PVH Hubs (It's actually the rear knuckle seal that causes them to clog up. The vacuum lines are problematic as well) - Alternators (although it may just be bad parts to blame) - Poor spark output on 3.0 (just get the upgraded coil from Ford) - Inner tie rods - Alignment after torsion bars are cranked (special cam bolts are necessary)
__________________
1998 Ranger XLT 4x4 SOLD ![]() 2003 Subaru Impreza WRX ![]() Still the 3.0's biggest fan. |
Tweet
#15 |
December 2009 STOTM Winner
Year: 2003
Make: ford
Model: ranger
Engine: 2.3 duratec
Class: 2wd street
Used For: daily driver
Rep Power: 11 ![]() iTrader: (0)
intake manifold ontrol valve on the duratech. dont remember what code it is but it seems pretty common.
Tweet
#16 |
Year: 2002
Make: FORD
Model: Ranger 4x4 ext cab 4.0 SOHC
Rep Power: 0 ![]() iTrader: (0)
Vibration from the rear end at speeds over 65MPH. Actually seems more like a buzzing sensation in your @$$ and in the gear selector. Tires and wheels are new, true and balanced. No one can seem to figure it out. U-joints apear to be in good condition and the bearings are good. If anyone else has this problem let me know.
Tweet
#17 |
Year: 2003
Make: Ford
Model: Ranger
Engine: 2.3L
Class: 2WD
Used For: Everything
Twice I had a problem when i started my ranger it would fire, rev to about 2000 rpm and then die. If I kept my foot on the gas it would run roughly but as soon as my foot came off the gas it died again after removing the key and trying again once or twice it ran fine im not sure if this was a computer problem or a problem with the chip in the key.
Tweet
#18 | |
Year: 1999
Make: ford
Model: ranger
Engine: 3.0
Class: 2wd
Used For: work and play
Quote:
i have had this problem several times with my 99 ranger and i have found that the ring and pinion in the rear end wears out and causes a vibration from the rear end and the cheapest and easiest way i have found to fix it is to install a new rear end in stead of rebuilding it. i hope this helps |
Tweet
#19 |
Year: 1998
Make: Ford
Model: Ranger XLT
Engine: 3.0 V6
Class: 2WD
stupid power steering in mine went out, kinda. plenty of power steering fluid but it will only work if I rev the engine a bit.
Dome/door ajar light. and tail gate wont latch sometimes, I just keep some wd-40 in the cab and that will fix it for a while.
__________________
Tweet
#20 |
Year: 2011
Make: Ford
Model: Lariat+ SCREW MaxTow Red Candy Met.
Engine: 3.5L EcoBoost
Class: 4X4 Off-Road
My 2003 3.0 Auto had a minor problem with a window that wasn't installed right at the factory. Since then - nothing. Not a problem. Maybe they should be excluded if they don't have any problems?
Oh wait, after 5 years I think my battery is getting a little soft and will need to be replaced before winter sets in - so we better keep them in the file. |
Tweet
#21 |
Junior Member
Year: 2002
Make: Ford
Model: Sport Trac
Engine: 4.0L SOHC
Class: 4x4
I've had 3 problems.
PVH hubs; Easy fix, either lock them or buy the AVM hubs. Drive shaft clunk; haven't fixed it yet. IAC valve noise; I just replaced the valve works great now.
__________________
B Rad |
Tweet
#22 |
Year: 2005
Make: Ranger
Model: XL
Engine: 3.0
Class: 2WD Street
Used For: I live in the country, what do you think I use it for?
2005 XL 3.0 5 Speed
I had 2 rearend rebuilds before 50,000 miles and need another one. I have a K&N FIPK and keep getting PO171 and PO174 error codes |
Tweet
#23 |
Year: 1999
Make: Ford
Model: Ranger XLT Sport
Engine: 4.0L V6
Class: 4x4
Rep Power: 10 ![]() iTrader: (0)
plugs + wiring at about 50,000 miles. Not sure if this is 99 specific or just regular maintenance tho
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
