Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 01-09-2011, 10:16 AM   #133
derangedranger92
Year: 1992
Make: Ford
Model: Ranger XLT
Engine: 4.0L
Class: 4x4
Used For: Daily driver/Off road
derangedranger92 is on a distinguished road
Default
Well i dont have a newer Ranger but my dad does and i work on it lol so here they are.
1. Spring shackes
2. Upper and lower ball joints
3. Tie rod ends
4. Door ajar switch
5. Rack and pinion
Other than that hes got 210,000 miles on it all original drivetrain and still going strong.
__________________
1992 Ranger XLT 4x4
4.0L
BW1354
M50D swap
BFG's
derangedranger92 is offline   Reply With Quote
Old 01-17-2011, 12:34 PM   #134
RangerJack
RangerJack's Avatar
Year: 1998
Make: Ford
Model: Ranger XLT LWB
Engine: 2.5 4 cyl
Class: 2WD
Used For: daily driver
RangerJack is on a distinguished road
Default
I just replaced the brake light switch due to having no brakes lights/tail lights and now the back up and license plate marker lights are not working..I have checked fuses and bulbs.
RangerJack is offline   Reply With Quote
Old 03-01-2011, 11:13 AM   #135
redneck243
Year: 1999
Make: ford ranger
Model: XLT
Engine: V6 3.0 flex
Class: 4x4 when the hubs get fixed
redneck243 is on a distinguished road
Default
99 V6 3.0 flex 4X4 114,00 on it
1) shift sensor thing on trans
2) new trans....had it in 4x4 in a snow storm for 4hrs and chewed up and spit out reverse
3) rear pinon seal
4) rear speed sensor
5) just took out the guts of 4x4 hubs casue the would not work or lock at random
6) and as with all NY trucks frame rust in rear and has to be fixed so i can get the new hangers on
and all the other stuff brought up here
redneck243 is offline   Reply With Quote
Old 03-03-2011, 08:16 AM   #136
ihateusernames
Year: 2000
Make: Ford
Model: Ranger XLT
Used For: everyday use
ihateusernames is on a distinguished road
Default
anyone have any suggestions as to were to start if my check engine light is coming on? I have a 00 Ranger XLT. Runs strong, clutch seems fine, the light just came on this morning driving to work
ihateusernames is offline   Reply With Quote
Old 03-06-2011, 12:24 PM   #137
tobyduck
Junior Member
Year: 1998
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 2WD
Used For: going to school, town, hauling equipment, fishing, etc.
tobyduck is on a distinguished road
Default
The IAC valve humming noise can be fixed easy instead of buying it used or new. That black cap on the side is actually an air filter. just pop it off (it might take some muscle, don't be scared that it will break off) take some needle noses pliers and take the cap apart. The outer cylinder and the inside, between those two pieces are two small circles of thin cotton. Mine were black because they were so dirty, I pinched some cotton off a cotton ball (not alot, because you don't want it to get clogged because that's what causes the noise) and just put it back together.
tobyduck is offline   Reply With Quote
Old 03-21-2011, 08:21 PM   #138
lilgreenranger
lilgreenranger's Avatar
Year: 99
Make: ford
Model: ranger XLT
Engine: 3.0 flex fuel
Class: 4x4
Used For: everything
lilgreenranger is on a distinguished road
Default
is there a forum on the pulse vac hubs
__________________
LIFT IT THEY CANT JUMP. YOU KNOW WHO IM TALKIN ABOUT
lilgreenranger is offline   Reply With Quote
Old 03-22-2011, 01:38 PM   #139
Cheezno6
Junior Member
Year: 86
Make: Ford
Model: Ranger
Cheezno6 is on a distinguished road
Default
Mine does the damnedest thing every Friday.
Pulls into the parking lot of closest strip bar and dies. Won't restart for at least 2-3 hours.
Haven't figured it out yet
Cheezno6 is offline   Reply With Quote
Old 03-24-2011, 01:41 PM   #140
Wildcat
Year: 1999
Make: Ford
Model: Ranger
Wildcat is on a distinguished road
Default EGR Code
I keep getting an EGR code when the engine light comes on, I have replaced the EGR valve twice and the EGR Solenoid. I continue to get a check engine light. The economy in the vehicle has gotten worse as well. Can not find any vacuum leaks and I have changed the spark plugs. Sorry, this is a 1999 Ford Ranger with the 3.0 engine and 4X4.
Wildcat is offline   Reply With Quote
Old 04-02-2011, 09:06 PM   #141
bg@f.ord
Junior Member
bg@f.ord's Avatar
Year: 2002
Make: Ford
Model: Ranger Edge 3.0 cranked with 31's cambered & aligned.1 of a kind.Chrome/white front.Pic soon........
Used For: Wife taxi
bg@f.ord is on a distinguished road
Default
I had to replace the fuel pump.@ about 120K I lost compression on a cylinder & had heads rebuilt,Batt.& Alt.wore out(expected).Rear diff. starting to slip & (min.) leak.I CRANKED my torsions but I installed the proper camber kit & got a lifetime alignment.31" BFG's aren't cheap.My fat a$$ & a friend fell on our ass after breaking the tailgate cables!!The seats suck a$$.I drilled ,macgyvered & installed high grade 1/4-20 hardware by the ratchet shaft & now it's solid,but the upper back support welds broke.I was told I have a cool ganqsta lean now.I hate the angle.Wrecking yard get ready.Still probably my favorite ride everrrrr!!!
bg@f.ord is offline   Reply With Quote
Old 05-04-2011, 08:41 PM   #142
rustedthrough
Year: 2001
Make: Ford
Model: Ranger 2wd
rustedthrough is on a distinguished road
Default
Oil pressure gauge flickers wildly on idling down from highway speed, straightens up at 1,000 rpm, flickers again below 1,000. No odd performance, no shaking, just the gauge. Should I be afraid?
2001 3.0, auto, 2wd
rustedthrough is offline   Reply With Quote
Old 05-11-2011, 03:47 AM   #143
RangerManxlt98
Year: 1998
Make: Ford
Model: Ranger
RangerManxlt98 is on a distinguished road
Default My 98 Ford Ranger 2wd 5spd
Lets start off with I LOVE MY TRUCK, But My truck does not love me.
90k miles on it i've had it since it had 49k
So far I've had to replace the Following,
A. Alternator 2x
B. Wheel Bearings 4x (yes had an alignment the first time.
C. Battery.
D. E break cable
E. Leaf springs
F. Leaf Shackles
G. Lead Hangers
H. Rear Shocks
I. Tailgate Assembly (latch and all)
J. Had to weld the frame on both sides, in the rear about a foot section.
K. Inner tie rods
L. Outer tie rods.
Now lets get to things i need to replace
A. Door Ajar switch
B. Wheel bearings Again...
C. Clutch, i have one for it.
D. Front Shocks
E. Heat controller? ( the fan speed only works on High.
F. The Exhaust ( where the manifold Connects to the Pipe down to the cat.
And thats my ford ranger :P a lot of time in this truck and plan to keep it for a lot longer.
Oh Ps, sounds like my valves are rattling as well Not sure what it is. Oh and my truck cool's down REALLLLLLLLLLYYYYYY fast for some reason Anyidea's? I mean its not a bad thing for it to cool down stupid fast ( time frame of 3-10 mins) but i would like to know why :P thanks!!!!
RangerManxlt98 is offline   Reply With Quote
Old 05-12-2011, 02:15 AM   #144
RangerManxlt98
Year: 1998
Make: Ford
Model: Ranger
Default Lulz!!
That has to be the best ranger ever. Ford should put a navi in the rangers and have it preset to Take you to the closest Strip bar, and Won't restart for at least 2-3 hours. I'd call it the Ford Ranger Win.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
