Adding Autometer gauges
clubracergt1
Coal City, IL
Since I hate factory Ford gauges (temp only shows cold to hot and oil pressure that reads "good") I am adding Autometer temp and oil psi gauges to my truck. I am curious, though, if I will be needing metric adapters for the senders. I will be replacing the factory units with the Autometer ones. Has anyone done this on a 3.0, and did you need adapters? I am just trying to have everything I need before I get started. BTW, it's a 3.0 (non-flex fuel) in an '03 Edge.
Thanks in advance.
Only the oil pressure "switch" needs to be changed to a Sender.
The senders are usually larger so need an adapter and extension.
But I would leave the switch connected so a "T" needs to be used, this keeps the "low pressure" warning light working, which can mean the difference between a total rebuild or just adding some oil.
You will need to run a new wire for both unless you want to pull the dash, and perhaps add a diode to the temp sender wire to the new gauge, senders are Variable Grounds, adding another potential ground via the second wire could cause both temp gauges to read incorrectly, diode isolates that.
Temp sender is a sender so does show actual temp if calibrated on new gauge accurately.
In '03 most threads will be metric, but Ford, and other auto makers, do throw curve balls at us just to keep things interesting, lol.
I will be replacing the factory temp gauge sender and the oil pressure switch with the Autometer units. The stock water temp simply bottoms out when unhooked. The oil pressure is on a gauge as well-not a light. I am not concerned with what that gauge does. I just don't trust gauges that simply show a 'normal' range. I like numbers. That's why the Autometer. As for pulling wires, I am fine with that. To keep it clean, though, I might use the factory wires, and just pull them from the back of the cluster. Again, I don't care if the stock gauges don't work correctly. I have to pull the cluster out, anyway, to fix a loose LED.
For the metric threads, that's what I am afraid of. The gauges came with SAE adapters, but not metric. Time to order more stuff.
Here is the dash wiring for 2003 ranger 3.0l
No dash warning light for oil, so not an issue.
Lots of metric/sae adapters just for what you are doing, common swap to get "real" oil pressure
Thanks, Ron. I've got an Alldata subscription to help me out as well. And, my metric adapters showed up today. Guess I know what I'm doing Saturday.
Got the gauges installed, and ended up not needing the metric adapters. The ones that come with the gauges are sufficient. I must admit, though, that installing the oil pressure sender was a joyous exercise in working by feel. Thank goodness this wasn't my first rodeo. Now, I just need to decide what to do about the factory gauges. I knew that they weren't going to work, but I forgot about the "check gauge" warning lamp in the cluster. When it's not raining, and I'm off work, I am going to see what happens when I just ground the stock oil psi sender wire. (Small things for another day.)
I forget what ohm but you can wire in a resistor in where the factory gauges used to connected to the factory sender and the go from there to ground. It will make the gauges "read" normal as soon as the key is turned on. I've been meaning to do mine( Just got done installing my boost/oil/temp gauges). When I find out the resistor value I will post it.
