The_Epsicle
- Mar 2, 2015
- Reaction score
- 2
- Location
- State of Boredom (Nebraska)
- Make / Model
- Ford
- Engine Size
- 4.0 Pushrod V6
- Automatic
- My credo
- All hail the mighty ziptie!
I was stupid I'm going to say that upfront, I had no idea what I was doing but I went ahead and tried to do it anyway. I drive a 1994 Ford Ranger 4.0, 1994 uses R134a it is not an R12 conversion. When I bought the truck the A/C did not work and when I check the pressure it was at 0 PSI. I tried to recharge the system and see if that's all it was, I got the pressure up to the proper level on the first can of R134a which is odd since it was only a 12 oz can and the sticker says it takes 21 oz of refrigerant. I went inside to check the vents and it was still blowing hot air, went outside to check the pressure and now it was in the danger zone on the high pressure side so I went to go shut it off on both but the high pressure gauge line exploded and sprayed refrigerant in my face(I called poison control and they told me to sit down so I'm writing this. ) I disconnected the end of the line and the valve closed so that's okay. So here's my problems
1. The system reached proper PSI before the proper amount of refrigerant was added.
2. At the proper PSI with the clutch engaged the system was blowing hot air through the vents on Max A/C. Though it was slightly cooler than before.
3. When I decided to plug the relay back in (since I jumped 12 volts to the compressor clutch) the clutch was engaging erratically, it was engaging only when the low pressure side reached 70 PSI, and disengaged when it reach about 30 PSI.
Will someone who's smarter than me please tell me what's wrong with my system?
EDIT: I went back outside and turned the truck on, the A/C clutch is still acting the same weird way. I rechecked the pressure and both the high and low pressure lines were reading around 40 PSI with the truck off, there didn't seem to be any noticeable leakage that I could see in the gauge's. The clutch did engage for about a full minute and I did notice the air in the vents getting cooler. My battery light is on now, I don't have a code reader right now but I'll let you know the code when I can.
EDIT 2: I was still a little lightheaded from the refrigerant when I posted that edit... just wanted to let you all know that I do know that indicates a charging system issue.
