Ford Hoarder
How exactly do I do this? Will the GM part bolt right up or do I need to modify something? Where can I find the weber carb that was mentioned in my last thread reply?
Generally speaking, the HEI module will get hot. So use a thick good sized piece of aluminum to transfer the heat-http://www.carbdford.com/tech/HEI/hei.htm
You can use the stock coil and mount the module to a good heat sync with the grease to transfer the heat.
