I know DJM makes a 2/3 and a 4/5, but is there any 3/4 kits out there for a 98 and up?
i dont think the 2/3 will be enough and i dont think my wheel and tire package will work with the 4/5
Well if you are wanting to piece a kit together, then yes there is parts out there.
If you flip the rear shackles and run a chevy lowering shackle you can net a 4in drop in the rear. And you can either go the route of Belltech 3in drop coils in the front, or Get the DJM upper and lower control arms and cut a coil out of the stock coils to get you the 3in drop in the front.
I would go the route of control arms only for the shear fact you are going to want to go lower and when that time comes you will be half way there.
