Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Need Urgent Help Fast! This section is being shut down. It was intended for people to get a quick answer while they're in the middle of a repair and need emergency help. The posts were then suppose to be moved to the proper forum. Unfortunately, that hasn't been done, and people are posting basic help questions in here.
Please scroll down and post your question in the proper forum
Thread Tools Display Modes
Old 09-06-2013, 12:15 AM   #1
rick68
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
rick68 is on a distinguished road
Default 94 ford ranger problem
I have a 94 ford ranger! It will start good cold but doesn't run weel it act's like a miss or bad hesatation in it but after it get's hot and you cut it off it won't start by the key switch but you can drift start it and get it going! I have replaced plug's,wires,fuel regulator,coil pack,icm. so if anyone could help I'd greatly appriecaite it.also it has the 4.0l engine in it
rick68 is offline
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-06-2013, 08:18 AM   #2
black_demon69
black_demon69's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger Splash
I use this vehicle for: For Out Running Dodges
black_demon69 is a jewel in the roughblack_demon69 is a jewel in the roughblack_demon69 is a jewel in the rough
Default
Quote:
fuel pump / fuel filter or both
did you check fuel pressure? should be between 30 and 40 psi if i am recalling specs correctly.
if pump is bad take bed off its much easier than pulling the tank. and replace fuel filter while you are at it
black_demon69 is offline
Old 09-06-2013, 10:28 AM   #3
RonD
Vehicle Year: 1994
Vehicle Make: Ford
RonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant futureRonD has a brilliant future
Default
Just to be clear, engine runs rough when cold but runs OK when warm?
When warm the starter turns over the engine at a good speed but engine will not start?
Could be a couple of separate issues.
Starter motor could be on it's way out, when warm the starter could be drawing too many amps which lowers the voltage at the coil, so crank starting won't work when engine/starter is warm but bump starting does.
Cold starter motor doesn't draw the extra amps.
I would test coil voltage with engine warmed up and starter turning, should be 10v or higher.
Could also be corrosion in wire ends, this raises the resistance in the wire and so reduces the voltage going to the coil.
Warm wire has more resistance than cold wire, so starts fine when wires are cold but not when wires are warm because of the extra resistance from the corrosion.
Fuel injected engines can't use a standard choke plate for cold starts, they use a sensor to tell the computer that the engine is cold and to run engine rich until it warms up, so poor operation when cold could mean a "choke" issue.
This is called the ECT(engine coolant temp) sensor, it is a two wire sensor.
There is also a one wire sender that looks similar, it is used for the dash board temp gauge.
two wire=ECT for computer << this is the Choke for EFI engines
one wire=sender for gauge
Easy to test this sensor
http://oldfuelinjection.com/?p=28
RonD is offline
Old 09-10-2013, 08:34 PM   #4
fordracing60
Junior Member
Vehicle Year: 1994
Vehicle Make: Ford
I use this vehicle for: fun
fordracing60 is on a distinguished road
Default
I had this problem awhile back. When its warmed and running wiggle the wires to the coil pack. Hope this helps
fordracing60 is offline
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
