Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Non Truck Discussions > Non RBV Tech
Non RBV Tech For discussing tech other than Ranger related.
Reply
Thread Tools Display Modes
Old 03-29-2008, 09:56 PM   #1
JFA_Spyderman
JFA_Spyderman's Avatar
Vehicle Year: 1969, 1994
Vehicle Make: Ford
Vehicle Model: Mustang, Ranger
I use this vehicle for: Daily Driver and Weekend Warrior
JFA_Spyderman will become famous soon enough
Default 2002 Hyundai Accent wont start
Yo,
The car is an 2002 Hyundai Accent, 1.5l, 5-spd. A great little car, gets around 37MPG. Anyway, I got back from a 5 day trip and the car would turn over, but not start. So i took a chance because i was far from home, and I rolled it down a hill and compression started it. It started so i went on.
I got home and turned it off, immediatly after i turned it off and on again, it started fine. The next day after the engine cooled down, it wouldnt start again. I comp started it again and drove it to the gas station to fill up. After i filled the tank, it wouldnt start again. So i rolled it down another hill and started it and drove it home.
I checked the plugs, they looked fine.
A fuel filter was reccomended to me, so I changed that and still no go. I also pulled the injectors and tried to start the car but no fuel came out.
Is there anything you guys can think of?
Thanks a ton!
__________________
1969 Ford Mustang, 1994 Ford Ranger (Under the knife)
"We will fight on the beaches, on the landing grounds, in the fields, in the streets, in the hills. We shall never surrender!" - Winston Churchill
"All that is necessary for evil to triumph is for good men to do nothing." - Edmund Burke
JFA_Spyderman is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-29-2008, 11:15 PM   #2
JFA_Spyderman
Vehicle Make: Ford
Default
Yo,
Update. I have fuel pressure up to the injectors, but the injectors do not seem to be opening. Anyone know a good way to test the injectors or what controls them? Thanks!
__________________
Old 03-30-2008, 12:03 AM   #3
Will
Super Moderator
Will's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: When I can't ride a motorcycle.
Will has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud ofWill has much to be proud of
Default
It starts when you roll it, but won't start on the functioning starter?
It starts every time you roll it?
I have to think that the main electrical feed goes through the starter and for some reason doesn't function while the starter is turning. I would check that out. See if the coil or something is getting power when the motor is cranking. I think it must not be. I've never been within a measured mile from a Hyundia so I don't know how they are put together but my feeling is the starter solenoid is somehow at fault.
__________________
'95 Ranger SC, old-type Duff brackets, hoops, springs & radius arms, Skyjacker rear springs, 4.0 5-spd, 13-50 manual, 4.10s, D35 Lockright, 31-spline 8.8 (discs, Trac-Lok), Superwinch Epi 9,000
'09 Mazdaspeed COBB Tuning--small but very angry.
'14 ZX1000M; '09 TU250X; '79 XLS1000
Will is offline   Reply With Quote
Old 03-30-2008, 12:22 AM   #4
JFA_Spyderman
Vehicle Make: Ford
Default
Yo,
Thanks Will, I'll try that tomorrow.
After a bit of research, I also found that these engines have both a camshaft position sensor, as well as a crankshaft position sensor. They send the pulsing signal to the injectors and tell them when to fire. They may also be linked to the ignition as well.
Thanks!
__________________
Old 04-05-2008, 08:44 PM   #5
JFA_Spyderman
Vehicle Make: Ford
Default
Yo,
FYI, turned out to be the crankshaft position sensor. Thanks!
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
