Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > Ford Bronco II's
Ford Bronco II's Be sure to check out the Bronco II Corral!
Reply
Thread Tools Display Modes
Old 07-10-2013, 08:42 PM   #1
jkufen
jkufen's Avatar
Vehicle Year: 1986, 1991
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Trail Rider, Street dragger
jkufen is on a distinguished road
Default 1991 Ford Ranger Blower Motor Relay Location?
I am having issues with my 91 ranger's ac. There is no power at the plug for the blower motor or resistor. There is power at the fan switch on the panel. If I put my ohm meter from the blower motor to the fan switch I get a positive reading so that tells me everything in that circuit is good. Anyways is there another blower relay located somewhere on the truck that I could check? I know I read somewhere that there isn't a relay from like 83-90 but I am not sure about 91. I have checked all of the fuses and everything is good so I can't figure out why there isn't power going from in the cab to under the hood. I also used the ohm meter to check the fan switch just in case it wasn't relaying the circuit and the switch came back functional. Any ideas where an issue could be? Everything seems good but I can't follow the wiring harness very far.
jkufen is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 07-11-2013, 04:56 AM   #2
martin
Vehicle Year: 1984 1991
Vehicle Make: ford
Vehicle Model: b2 explorer
martin is just really nicemartin is just really nicemartin is just really nicemartin is just really nice
Default
behind the passenger side headlight, check out the tech library.
martin is offline   Reply With Quote
Old 07-11-2013, 05:36 PM   #3
jkufen
jkufen's Avatar
Vehicle Make: Ford
Default
Well I checked for the relay and I guess my truck doesn't have one. So I am back to the drawing board on why I don't have power at the blower motor.
Old 07-11-2013, 06:26 PM   #4
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Well, power to the switch should tell you that the problem isn't with a relay, if it has one.
Power into the switch also rules out fuses and a number of wiring issues.
But you say you don't have power after the switch.
Hmm. Sounds simple to me.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 07-13-2013, 09:03 PM   #5
tidmarshsmiths5
tidmarshsmiths5's Avatar
Vehicle Year: 1985
Vehicle Make: Ford
Vehicle Model: Bronco II XLT
I use this vehicle for: Taking me to the outdoors and some light towing.
tidmarshsmiths5 is on a distinguished road
Default
...wiring is hard for me so I'm not an expert by any means...as a matter of fact, I'm less than a novice!
I ordered one from RockAuto and replaced mine (it worked on high only but no other setting)...I think I paid $12 with shipping...may be worth looking into as the resistor could be bad...if not, you've got a wire issue...and that my friend is no fun (if you jiggle it, does it come on at all - the wires - move them around to see if you can get a contact but my bet is still the resistor)...good luck!
tidmarshsmiths5 is offline   Reply With Quote
Old 07-14-2013, 04:58 AM   #6
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Default
If the resistor isnt getting power then it probably isnt the problem.
Think about electrical stuff like a road with a bunch of bridges along it. Each switch is a bridge. If something doesn't work you find the last place the power can get to and that is where the bridge is out.
Postin' from teh Galaxy
__________________
Old 07-15-2013, 01:42 PM   #7
jkufen
jkufen's Avatar
Vehicle Make: Ford
Default
Yeah I went back and forth on whether the switch was bad or not. I put my ohm meter on the switch and there is a good current through the switch. I guess I could go to the parts yard and try and get one. I know new this thing runs $100 and that is why I was trying to avoid buying one. I guess this pay day I can run to the junk yard and snatch one off and get a compressor.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
