Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > General Discussions
General Discussions This forum is for general discussions. If you're in need of help, post it below in the appropriate topic forum.
Reply
Thread Tools Display Modes
Old 06-26-2013, 06:34 AM   #1
bluebombersfan
Vehicle Year: 2006
Vehicle Make: Ford
Vehicle Model: Ranger Sport
bluebombersfan is on a distinguished road
Default How hard is it to move the gas tank a little?
Thing is I bought a camper for my truck this past summer and I need to install the belly bar or whatever its called to the bottom of my frame. Problem is the gas tank is in my way. I can't bolt the darn thing because the gas tank is right beside the frame. I just can't get my hands in there to bolt it up.
I went to my shop and they wanted $150 to do this job I was like no thank you. Is this really that complicated to move the tank a little then back?
I don't think there is no other option, can't weld it either that would be to dangerous.
I was really disappointed with this whole thing. When I first bought it I was hoping I could do this for free, now I might have to shell out $150 plus tax to get this done.
bluebombersfan is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-26-2013, 07:54 AM   #2
97RangerXLT
Super Moderator
97RangerXLT's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT Supercab 4 x 4
I use this vehicle for: Putting wear and tear on my tools
97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute97RangerXLT has a reputation beyond repute
Send a message via MSN to 97RangerXLT
Default
Not difficult to do. drive your truck around until you have a near empty tank.
Crawl under and remove the two bolts that hold the straps, and the tank should drop. the straps are held to the frame via t shaped notches and once you have them loose, a quarter turn either way should disengage them from the frame. Be sure to wear safety goggles as a whole ton of dirt will come down into your eyes when removing the bolts and tank.
You will also want to support the tank underneath so that it does not break the lines.
you might even get away with removing one strap and loosening the other. it will droop about 2 inches on the strapless side, that might get you enough room to do what you need to do.
Definitely not worth taking in for $150
AJ
__________________
Quote:
Originally Posted by soylent_green View Post
"If it weren't for physics and law enforcement, I'd be unstoppable!"
Quote:
Originally Posted by adsm08 View Post
After a 5 year review of the work of automotive engineers I have determined that every last one of them is an atheist. Looking carefully at their work it is quite apparent that not a single one believes in intelligent design.
Quote:
Originally Posted by robertc1024 View Post
Hey - we all have to help each other. Otherwise, we'd become an S10 forum and we'd all kill ourselves.
http://www.therangerstation.com/foru...ad.php?t=13474
97RangerXLT is offline   Reply With Quote
Old 06-26-2013, 09:12 AM   #3
PanamaExpat
PanamaExpat's Avatar
Vehicle Year: 1994
Vehicle Make: Mazda
Vehicle Model: B4000
I use this vehicle for: reckless experimentation
PanamaExpat is just really nicePanamaExpat is just really nicePanamaExpat is just really nicePanamaExpat is just really nice
Default
If your tank has the skid plate it can be a bit more fun to get loose. If you run into a snag it only takes a few minutes and a buddy to remove the bed. 6 T55 bolts in the bed, 3 screws on the filler neck, unplug the tail light harness right behind the back bumper. Bed is really light weight but it is awkward to handle by yourself to lift it high enough to clear the frame and set it off to the side. Hence reason you need a buddy.
__________________
"Rust never sleeps."
Just because I never finish anything doesn't mean I don't work on it.
Cheers:
PanamaExpat
AKA: Jim
PanamaExpat is offline   Reply With Quote
Old 06-26-2013, 09:44 AM   #4
snake
snake's Avatar
Vehicle Year: 2002
Vehicle Make: Ford
Vehicle Model: The mighty Ranger
I use this vehicle for: cruising for chicks
snake is on a distinguished road
Default
If you need to drop the tank down and not disconnect the lines use plastic milk crates- drop the tank down onto them while you work. Then lift one side up and connect a strap, raise the other and connect it. Works like a charm.
__________________
2002 XLT in wedgewood blue, 4.0 auto, 4 doors (no waiting) MP3, 3:55 limited slip rear, payload package, factory installed trailer hitch, side step bars. Built 7/31/2002, shipped 8/19/2002, purchased 9/25/2002 sold 8/2011.
2011 F-150 crewcab ecoboost twin turbo. Purchased 7/13/2011
snake is offline   Reply With Quote
Old 06-26-2013, 09:26 PM   #5
pjtoledo
Premium Member
Vehicle Year: 2000 2005 199
Vehicle Make: Fords
Vehicle Model: Rangers Taurus SHO 5spd
I use this vehicle for: going to Cabelas
My credo: get outta my way, I'm falling!
pjtoledo has a spectacular aura aboutpjtoledo has a spectacular aura about
Default
not that hard. had to move the tank on my 2000 4x4 to access the sway link stud a few years ago.
Perry
pjtoledo is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
