Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Bulletins (Welcome, News/Announcements, Problems & Submissions) > Need Urgent Help Fast!
Need Urgent Help Fast! This section is being shut down. It was intended for people to get a quick answer while they're in the middle of a repair and need emergency help. The posts were then suppose to be moved to the proper forum. Unfortunately, that hasn't been done, and people are posting basic help questions in here.
Please scroll down and post your question in the proper forum
Thread Tools Display Modes
Old 04-14-2013, 11:44 PM   #1
countryboy69
Vehicle Year: 2000
Vehicle Make: ranger
Vehicle Model: step-side
countryboy69 is on a distinguished road
Exclamation parasitic draw 2000 ford ranger
Hey yall, i have a 2000 ford ranger, i have a parasitic draw problem. I ran the test and im pulling a 1/4 amp after they key is off and out of the ignition there is no lights on and i checked for voltage at each fuse and narrowed it down to the right one. When i pull out fuse 26 the draw dies out. In that circuit i have the GEM module, the trans shift module and a few others i cant remember without all data in front of me. I was wondering if anyone has seen this problem and if they found an easy fix, maybe a stuck relay of something? If you got any ideas or if youve had this problem hit me up idk if ya txt me or email what ever works but i wanna get this fixed so i can get the new battery too the battery has been recharged and drained so many times because of this problem that it is now trash and i do not wanna let it go too long then ill burn up my alternator. Hit me up.
Andrew.
231-632-8889
or
andrew_villafane@yahoo.com
If and when ya message me just let me know what your messagin me for haha dont wanna get to confused thanks guy! hope to hear from somebody!
countryboy69 is offline
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 04-15-2013, 03:02 AM   #2
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Vehicle Year: 1991/2002/2008
Vehicle Make: Ford
Vehicle Model: Ranger/SportTrac/SuperDuty
I use this vehicle for: Play toy/Daily Driver/Tow Rig
Sasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud ofSasquatch_Ryda has much to be proud of
Send a message via MSN to Sasquatch_Ryda
Default
How long are you letting the vehicle sit after setting up for the draw test? You need to leave it so all modules power down before testing. This can take anywhere from 10-30 minutes.
__________________
1991 Ranger - one tons, 3 link, air shocks and 40's
2002 Explorer Sport Trac - torsion crank, body lift, 35's
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline
Old 04-15-2013, 03:28 AM   #3
countryboy69
Vehicle Year: 2000
Default
I let it sit for an hour. Something is staying on I'm.thinking a relay is stuck on or something ....
Old 04-15-2013, 03:30 AM   #4
countryboy69
Vehicle Year: 2000
Default
I've seen many people on here have this problem with my exact make year n model of truck but they never post the solutions ....
Old 04-15-2013, 08:14 AM   #5
Andy D
Vehicle Year: 94
Vehicle Make: The Rat
Vehicle Model: 4x4 4.0 5spd Vise grip shift 1354 E, manual hubs
I use this vehicle for: mini pick up stuff
My credo: to prevent Found On the Road Dead, Fix Or Repair Daily
Andy D has a spectacular aura aboutAndy D has a spectacular aura about
Default
The radio in the Rat will draw down the battery in short order. I am considering a solar powered battery minder, or a switched battery terminal.
GENERIC ADVICE: OK, so you have the problem narrowed down to a single circuit. Next you have to divide the circuit and test each half. One part will still have the draw, one won't. Keep reducing the bad part , until it you have it nailed. It is long and tedious , if you dont get lucky. Good luck.
Andy D is offline
Old 04-15-2013, 08:43 AM   #6
Earl43P
Premium Member
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: a driveway ornament, light hauling
Earl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really niceEarl43P is just really nice
Default
Read this:
http://flashoffroad.com/electrical/B...teryDrain.html
and do you have PDL, PW, and remote entry (key fobs to lock/unlock)?
You'll need to latch the door latch with the door open (dome light goes off, door ajar light goes out) in order to do the testing.
You'll find that "relay box" by laying on the DS floor, looking up into the dash, center. It is about 6" wide, black plastic with tape around it. Look for these color wires going to it:
TN/YE (tan with yellow stripe)
VT/OG
LG/OG
WH/BK
__________________
If at first you don't succeed, RTFM.
82 GL1100 Bratbike
93 GL1500I DD
99 Valkyrie IS
08 Rav4 Sport "boring"
Earl43P is offline
Old 04-15-2013, 03:24 PM   #7
naford
Vehicle Year: 2002
Vehicle Make: Ford
naford is a jewel in the roughnaford is a jewel in the roughnaford is a jewel in the rough
Default
On my 01 Mustang if I leave the ventilation in anything but off it will drain the battery in about a month.
naford is offline
Old 04-16-2013, 11:56 AM   #8
countryboy69
Vehicle Year: 2000
Default
I figured it out! My battery was just junk which I knew but the GEM mod on fuse 26 takes anywhere from 45min too an hour n a half to go to sleep. This whole time it draws between. .50 amps to. .261 amps mine took 1.5 hours to go to sleep this draw for that amount of time killed my battery. After the 1.5 hours it went to spec. .05 amps of parasitic draw. Thanks for the help tho!
Bookmarks
Tags
2000 ford ranger, battery drain, parasitic draw
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
