88 Ranger 302 Swap
OlBlue
2.9
I have a 1988 Ranger XLT 2.9, Im wanting to do a 302 swap. What Year of motor and trans would fit the best. It has a 2 inch body lift on it now.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
TRS Banner 2012-2015
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Any 302 engine will fit. Any car or explorer intake will fit. F and E series intakes will not fit. I suggest using a 96-97 explorer motor and ecu/harness for ease of wiring...
SVT
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,520
SW Iowa
Engine Type
V8
5.0
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Probably not a big issue yet but stick with the pushrod 302/5.0's. :icon_thumby:
Good point. Any OHV will fit. However, the OHC 302 will also fit, but much more fabrication is needed. Then again, if you can afford $9k on a crate engine, your not worried about fitment issues :D
SVT
OlBlue
2.9
Thanks for the info, I don't want to spend a fortune on this build. I am looking at older 302s I want to go carbureted. Would the wiring be more difficult if I chose the route ?
dangerranger83
5.0 HO under the hood!!!
Solid Axle Swap
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
Take a look at my build. Did a carb 302 swap on a roller engine that i converted to HO. I used an hei dizzy to eliminate a few wires.
Sent from my rooted SPH-D710 using Tapatalk 2
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,520
SW Iowa
Engine Type
V8
5.0
SVT
A mere mortal Mustang GT (not Boss) crate is only $6k, the street value of one out of a wrecked Mustang or F-150 would likely be significantly less.
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
A crate engine is about $6800, the wiring harnes and ECU to run it is about $1900 and change. Add tax, your over $9k. I'll be looking for a wrecked 2011 5.0 in the next year or two, for my early bronco powerplant.
The wiring is not hard at all. The explorer 5.0's run off a 42 pin plug, which everything goes through. You only need about 5 wires of that plug for the motor to run. Add a couple more for oil pressure and water temp, add 3 more for OBD2 port. Splicing these wires into a couple of plugs off the original motor in your 88, and you will have a simple harness with no major wiring. Fuel lines should be plug and play, as they are long enough to reach from the trucks lines to the engine's lines. You can reuse the stock exhaust manifolds till you decide to upgrade to headers.
Going carb you will have to change out the intake manifold, rewire the fuel pump relay, install a fuel pressure regulator, as well as still wire up your oil pressure and water temp to the trucks harness. Unless you already have the intake and carb, they can be extra $$ not set aside for the build. I have done both, efi and carb to efi vehicle swaps, and I prefer staying with efi. To me, its much easier. I'd be happy to help you with the wiring if you need it...
SVT
OlBlue
2.9
Thanks everyone for all the input, @RangerSVT so where would be the best place to get a motor etc.. And what would be a ballpark price for the whole swap?
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
If you can swing the cost up front, I strongly advise getting a donor so you will have everything you need (motor, trans, harness, ecu, cruise module[may or may not be the same design as the 94 model], throttle cable, alternator harness, power steering pressure line, radiator, and exhaust up to the trans xmember if you can get it. Otherwise, you will need to source these from a junkyard. I'm currently trying to source a 96-97 donor for Josh's (josh40601) D-ranged truck that I'm doing...
SVT
bobbywalter
TRS Technical Staff
TRS Event Staff
TRS Technical Advisor
Ugly Truck of Month
4,667
woodhaven mi
FORD mostly
Engine Type
V8
BIGGER
2WD / 4WD
sawzall?
it is easier to fix and understand than "her"
josh needs a 6.0
RangerSVT
Oct 09 OTOTM
OTOTM Winner
Solid Axle Swap
RBV's on Boost
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
He's eventually going 4bt, for now he's doing a v8 that will eventually go into his early bronco, which he wants to keep all ford...
SVT
OlBlue
2.9
Ok I have found a 1980 mustang for cheap. But the motor is carboratered!
dangerranger83
Solid Axle Swap
54
Lafayette, IN
And a non roller. It's a 255, not worth getting unless it has had a different engine put in.
OlBlue
2.9
It has a 302 in it. Could I use that's transmission, I still want 4WD?
Staff online
Kirby N.
March Truck of The Month
