Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-04-2013, 06:18 PM   #1
dispatchrobb
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II
I use this vehicle for: DD
dispatchrobb is on a distinguished road
Default 2.9 slow starting issue
Have a BII with 2.9L and the 4.0L flywheel, clutch, and starter. It has to crank a couple times and it starts up, but when it's warm it doesn't start. I can crank and crank and crank and nothing. The battery is new, the starter is new. I had it at auto zone and they said the alt, batt and starter were good, and I've cleaned all the terminals. I can hook up jumper cables to it when it won't start and it cranks much faster and starts immediately. I had a battery charger on it and then it cranked up fast and started right up, but it seems like it goes down to a lower level and stays there.
My questions are, it's the 2.9 batt with 650 cca, so does the 4.0L starter need a bigger battery? Sometimes my Alt gauge reads a tad low, so is there a possibility that the battery is just not getting a full charge but the alt still tests in the normal range, or maybe the voltage regulator is bad?
Just looking for a place to start rather than just throwing a new alt on it and not fixing the problem.
dispatchrobb is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 02-04-2013, 06:23 PM   #2
doorgunner
Lab Rat for V.A. hospital
doorgunner's Avatar
Vehicle Year: 1934/1989
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: FUN on a daily basis!
My credo: JESUS (no-not HeySoos) Lives!
doorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond reputedoorgunner has a reputation beyond repute
Default
My '89 did the same thing....ended up changing all the battery cables (and the extended cable that goes from the frame to the engine)......that solved my starting problems....(also upgraded to a 850 C.C.A. battery)
__________________
*******Click on My Stupied Build Thred! http://www.therangerstation.com/foru...ad.php?t=30561*******
**All the people who's freedom of speech I fought to defend are now telling me to shut up**
doorgunner is offline   Reply With Quote
Old 02-04-2013, 08:32 PM   #3
kimcrwbr1
kimcrwbr1's Avatar
Vehicle Year: 1983
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: DD tow boat
kimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to beholdkimcrwbr1 is a splendid one to behold
Default
The amp guage should never read discharge even a little do you have a ground wire from the alternator chassis to battery negative?
__________________
it takes a nickle to go first class
when it stops hurting it will feel alot better
kimcrwbr1 is offline   Reply With Quote
Old 02-04-2013, 10:41 PM   #4
a31ford
Electronics GURU
a31ford's Avatar
Vehicle Year: 1988
Vehicle Make: Ford
Vehicle Model: Ranger XLT (Custom Frame) With a 3" body lift
I use this vehicle for: Working on "Breakout Box for ECM's"
a31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to alla31ford is a name known to all
Default
Many people overlook the ground wire, As doorgunner said...
Here's a hint, ever see a car coming at you with one really dim headlamp ?? THAT my son, is a bad ground.
Look at ALL, I repeat, ALL the grounds, engine to frame, engine to battery, battery to frame.
even 1 ohm of resistance in ANY of these, will turn a starter into a gutless wonder.
Greg
a31ford is offline   Reply With Quote
Old 02-06-2013, 03:03 PM   #5
dispatchrobb
Junior Member
Vehicle Year: 1989
Vehicle Make: Ford
Default
Thanks for the info!
I forgot to mention that after it starts, the gauge lights pulse dim to bright to dim to bright about three times and the amp gauge needle follows the same pattern then it's all normal. lights don't appear to dim when I turn other things on or needle doesn't move with the blinker or anything like that. I'll check all my grounds again and see if that's it. The alternator seems to have all the wires attached, is the chassis ground from the alt to battery neg something I should add or should one of the wires already be attached? It's an "upgraded higher amp" alt the previous owner installed so maybe he missed something.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
