Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-15-2012, 08:24 AM   #1
johnnygarcia185
Vehicle Year: 2000
Vehicle Make: Ford
Vehicle Model: Ranger
johnnygarcia185 is on a distinguished road
Default valve cover gasket replacement
I recently just bought a 2000 ranger 2.5 and believe i have a leak coming from the valve cover gasket. What im asking is for.some insight on how to replace it and what surprises might to be expected, also which company i.should buy.the actual gasket from bosch,ac denco etc.
johnnygarcia185 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 11-15-2012, 10:56 AM   #2
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Vehicle Make: Dordge
Vehicle Model: Care A Van
I use this vehicle for: Space travel
My credo: Love Thy Neighbor
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
Not sure with that engine what surprises you might encounter, but did you try to tighten the VC or check the bolts? Vibration can cause them to back off a bit and might be all it needs is tightening...but don't over torque them because it can cause a leak...or worsen the situation...I think they are something like 15 inch pounds of torque but I don't have my manual handy...
I've used the blue rubber VC gaskets for quite a while...they tend to stretch once heated so they are not a good choice if you have to remove the VC and they are about four times the price of a cork gasket.
I've seen some actually glued onto the VC base...meaning this is a common problem with these engines...
__________________
Rome and my Ranger were not built in a day...
1988 Ranger 2.0 5 spd (gone)
1988 Ranger 2.3 " (gone)
1996 Ranger 2.5 (gone)
On-line manual link
http://www.therangerstation.com/foru...94#post1581294
Mark_88 is offline   Reply With Quote
Old 11-15-2012, 12:47 PM   #3
Mikel89us
Vehicle Year: 1989
Vehicle Make: Ford
I use this vehicle for: On/Off Road/Hauling
Mikel89us is on a distinguished road
Default
I prefer the blue rubber gasket, you can get one from FelPro. They do tend to stretch, but they are re usable, i have had my valve cover off too many times to list, and always use the same gasket for the last 4 years at least. The cork gaskets leak easier and are temperamental to proper torque and a perfectly smooth VC. The rubber is never going to get over-tourqued because of the steel rings at the holes, you will strip out the bolt hole before you compress it too far (ive done it). before you go and do it make sure your EGR tube will come loose from the ends if its in the way.
__________________
'89 2.3 Ranger 4x4, 2.5 stroker, 4 plug conversion, 10.5:1 C/R, and Jeep Dana 30 axle, 4.5" susp lift, 3" body lift, 33x12.50 MT's
'91 Mustang 2.3 11.2:1 C/R 5 Speed swap 5 Lug conversion
Mikel89us is offline   Reply With Quote
Old 11-15-2012, 04:09 PM   #4
rangerbum
rangerbum's Avatar
Vehicle Year: 85
Vehicle Make: Ford
Vehicle Model: BroncoII
I use this vehicle for: Leaving me stranded, broke, and madder than you can imagine.
rangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nicerangerbum is just really nice
Default
The valve cover bolts come out easy, but when you go to pull the cover off, you will need to twist it and pull it at an angle to get it out. The back will not want to lift past the firewall and wire harness that runs to the ecu. Remove the bolts holding the harness in place, so you can manipulate it. Be patient and rotate it until you find the sweet spot. And take your time before cinching down the cover, as you put it back on it usually moves the gasket out of place. So be sure its strait!
Any job worth doing is worth doing right!
__________________
My 2.8 is about to have an out-of-body experience....permanently in liu of 4.0
rangerbum is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
