Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 11-05-2012, 09:22 PM   #1
Dune Runner
Dune Runner's Avatar
Vehicle Year: 1999 4.0
Vehicle Make: Ford
Vehicle Model: Ranger Xcab
I use this vehicle for: Daily Driver/ 4 Wheelin
Dune Runner is on a distinguished road
Default Help! Can't figure out lean codes.
Ok 99 4.0 OHV. So far this truck has had the fuel pump, MAF, TPS, Intake gaskets, two O2 sensors, Injector O rings, replaced.
Two independent shops and the dealer have gone through the truck. The PCM has been reprogrammed with updates. It has been checked for vacuum leaks many times. I even checked myself. I reset the ECU and within two days the CEL is back on.
Im stumped. The truck runs great and otherwise has no problems running ,starting , idling or driving.
Any ideas? It's been smogged and won't be due again for two years so it's not a pressing issue but Im anal about things and it bugs the crap out of me not knowing what's wrong. BTW this truck came stock with no EGR system. The codes are lean bank 1&2.
Dune Runner is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 11-05-2012, 09:32 PM   #2
adsm08
Premium Member
Asteroids Champion
adsm08's Avatar
Vehicle Year: 1987
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Making money and being broke.
adsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond reputeadsm08 has a reputation beyond repute
Send a message via AIM to adsm08
Default
Do you have access to a scanner that will do live data?
I have a few good tests to give you but I need you to have a scanner that does live data.
Not saying this is your problem, but I have seen lean codes caused by failing injectors without any other driveability symptoms.
__________________
Project: Hillbilly Deluxe
Project: Amazing Grace
Project: Cash 'N Carry
Project: 12-Volt Sandwich, project finished
Project: Birthday Present
Quote:
Originally Posted by The Doctor
Hunger looks very much like evil from the wrong end of the cutlery.
I like it when things catch fire and explode, which means I do not have your best interests in mind.
adsm08 is offline   Reply With Quote
Old 11-05-2012, 09:37 PM   #3
Dune Runner
Vehicle Make: Ford
Default
No scanner but the Ford dealer had one on it. They had it all day and were stumped too.
Old 11-05-2012, 09:54 PM   #4
Dune Runner
Vehicle Make: Ford
Default
Im hoping you guys might have more ideas on it. I have been spending all my free time trying to figure it out.
Things I have thought of but haven't checked yet like a bad gas cap, Bad connection somewhere, EVAP purge valve leaking, Stuck PCV, Leaking dip stick, You know the stupid stuff. I have to write them down as I think of them so I can check them the next day.
Old 11-06-2012, 06:47 AM   #5
john93rangerstx
Junior Member
Vehicle Year: 1993
Vehicle Make: ford ranger
Vehicle Model: stx
john93rangerstx is on a distinguished road
Default
craked intake when it cold it shrinks and leaks i have seen people silicon a crack they made and it come bake weeks later
john93rangerstx is offline   Reply With Quote
Old 11-06-2012, 08:28 AM   #6
Dune Runner
Vehicle Make: Ford
Default
Quote:
Nope, The intake has been off the truck and inspected.
Old 11-17-2012, 09:49 PM   #7
gator1gear
Vehicle Year: 2000
Vehicle Make: Ford
gator1gear is on a distinguished road
Default
I have a 2000 Ranger 4x4. I drove myself crazy trying to find the cause of my lean code. I changed the fuel filter and cured it. I know it sounds strange, but it fixed mine.
gator1gear is offline   Reply With Quote
Old 11-17-2012, 10:03 PM   #8
Dune Runner
Vehicle Make: Ford
Default
It has a new filter and pump. Im replacing the filler hoses in the AM
Old 11-17-2012, 10:07 PM   #9
gator1gear
Vehicle Year: 2000
Vehicle Make: Ford
Default
Quote:
I hope ya get it! I imagine it's pretty frustrating Good luck!
Old 11-18-2012, 07:55 AM   #10
Tominator
Premium Member
Tominator's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
I use this vehicle for: Self Gratification
Tominator is a splendid one to beholdTominator is a splendid one to beholdTominator is a splendid one to beholdTominator is a splendid one to beholdTominator is a splendid one to beholdTominator is a splendid one to beholdTominator is a splendid one to behold
Default
Clean the MAF.....
__________________
1995 w/Ford crate motor GT40X heads Tri-Y Flowmaster40s GT40 Intake. Custom Paint. OZ Racing w/Sumitomo rubber. 5-7 drop w/Dreambeams/Flip Baer Racing brakes w Stang disc rear. S-Trim w/meth. Viper Spec Tremec......and that's just the outside!
Tominator is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
