Longer front driveshaft???
UrbanRedneckKid
15+ Year Member
Solid Axle Swap
Cass Co, Missouri
Isn't there an Exploder front shaft that is longer than the Ranger shaft?
If not has anyone found a j-yard shaft that works well with a EB D44 SAS?
I have a 1354m that needs connected to my D44...
Thoughts on choppin and extending my factory shaft....
Sent from my PG86100 using Tapatalk 2
The Explorer front shaft is longer than some Ranger front ones, namely the 87 and older with manual trans. In 88 the FM146 came out and the FM146/M5OD/A4LD are all the same length.
So... What's longer than my factory 94 shaft? 4.0 M5 1354E D35
I've heard a report that the driveshaft in a Ranger with the D28/35 hybrid axle is about an inch longer. I have not verified this though.
As for extending a driveshaft, it can be done, but you gotta make damn sure it's straight afterward if you ever want to go more than about 30 MPH in 4WD. More than a mm or so out of whack and you'll have a hard time balancing it.
