bozo4ford
- Feb 10, 2010
- Reaction score
- 0
- Location
- Anaheim
- Make / Model
- Ford
- Engine Size
- 2.3L 140 CID
1986 2.3 FORD RANGER Gas / EFI / 140 CID
4-Cyl. / 5-Speed / SOHC / base Cab.
_______________________________
I want to remove, and take my Distributor Coil, TFI (Ignition control module) and my EEC-IV (Electronic Engine control) part to autozone to test.
having a 1986, I have personally replaced about four TFI's on this truck. They are infamous for rangers to fail from time too time.
I recently replaced my fuel filter, but not my in-line pump, I feel I'm getting fuel to the injectors, but it cranks, but does not turn over, which leads me to believe this could be a spark issue. Spark plugs and wires are fine. I have not tested my fuel pressure yet.
My search for the location of this EECV-IV is confusing. Yes, I do have the fuel pump relay, the blower fan relay, and the ECC (or EEC) relays on passengers' side fender well, in the same area.
Some say the EEC-IV is in the inside cab, middle, under the dash. Well, I looked and I did see a little box with wires going to it attached to the dash metal frame, but this is not what I believe to be looking for, which is a little bigger. Others say it's in the very right side, pass. kickwall, behind the plastic cover.
CAN ANYONE TELL ME PLEASE....EXACTLY WHERE THE EEC-IV IS?
Thank You !
Thank You !
