Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-13-2012, 10:15 PM   #1
Cricket
Junior Member
Vehicle Year: 1990
Vehicle Make: Ford
Vehicle Model: Ranger XLT
Cricket is on a distinguished road
Default coil pack problem
90 2.3 no spark on#2 and 3 passenger side coil pack, new wires,plugs coil pack.tested all-- ign.module ,wires, etc.did a spout test , inside cab got wet durring a tropicsl storm. truck wil run ,,<,like crap> engine light stays on cannot retrieve a code please help ,thanks
Cricket is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-13-2012, 10:21 PM   #2
Cricket
Junior Member
Vehicle Year: 1990
Vehicle Make: Ford
Default
forgot to mention tachometer fluxuates on crickets ranger post
Old 09-14-2012, 03:08 PM   #3
FritzTKatt
FritzTKatt's Avatar
Vehicle Year: 04
Vehicle Make: Ford
Vehicle Model: Ranger XLT ext. cab
I use this vehicle for: DD.
FritzTKatt will become famous soon enoughFritzTKatt will become famous soon enough
Default
Did you swap the coil packs out? Is possible you got a bad one from the store. It'll take 5 minutes and if it doesn't work, oh well. But if it does then you saved yourself quite a headache. If they are both "good" or bad, then you likely won't see a difference. Are your connections clean? Dielectric grease them, lightly.
I had a bad primary coil on my old truck (94 2.3) and swapped them out so it would run (to the store). Put the new one on the primary side and the old/good one back to the secondary.
__________________
4.0, 5 speed, warn 37780s, lockrite, 31x10.5 duratracs. Winch bumper, Warn M8000
FritzTKatt is offline   Reply With Quote
Old 09-14-2012, 09:57 PM   #4
Cricket
Junior Member
Vehicle Year: 1990
Vehicle Make: Ford
Default Coil Pack Problem
Yes I swapped out coil packs & it made no difference. Forgot to mention that this problem happened due to driving through 3 ft. of water during Tropical storm. Had driven through water like this before & never had any problem.
Water came in the cab. I noticed water was around the computer housing & on the top.
Old 01-03-2013, 09:41 PM   #5
captanron
Vehicle Year: 1991
Vehicle Make: Ford
captanron is on a distinguished road
Default coil packs
is there a difference between the coil packs?
captanron is offline   Reply With Quote
Old 01-12-2013, 08:58 AM   #6
PetesPonies
Vehicle Year: 1984
Vehicle Make: Bronco II
Vehicle Model: V8
I use this vehicle for: fun
PetesPonies has a spectacular aura aboutPetesPonies has a spectacular aura about
Default
No, there is no difference between the coil packs. Just that the right pack fires to start the engine, then both are operating.
__________________
Pete's Ponies
Mustang RUSToration & Performance
PetesPonies is offline   Reply With Quote
Old 01-15-2013, 07:08 PM   #7
logman7777
Junior Member
logman7777's Avatar
Vehicle Year: 1995
Vehicle Make: Ford
I use this vehicle for: Everything
logman7777 is on a distinguished road
Send a message via Yahoo to logman7777
Default
Just for giggles disconnect your negative battery terminal then unplug your brain then either spray connector and CPU liberally with wire dry or use compressed air to blow any moisture from the connector and/ or the CPU box. You may have some stray water shorting out some signals in a best case scenario. worst case you are chasing through your electrical system or replacing the brain.. GOOD LUCK either way..
logman7777 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
