Go Back   The Ranger Station Forums > Engine & Transmission Forums > V6 Forums > 4.0 Liter Forum
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 03-11-2008, 05:42 PM   #1
mixwhit
Junior Member
mixwhit's Avatar
Year: 2003
Make: Ford
Model: Ranger XLT Ext Cab
Engine: 4.0L V6
Class: 2WD
mixwhit is on a distinguished road
Default when should the timing chain get replaced?
I'm looking at purchasing an '03 with a 4.0L V6 and 158k miles. I'm guessing it's probably due for a timing chain replacement if I buy it, although I haven't been able to find a maintenance schedule online. Anyone know what the maintenance interval is for it?
Also, is there anything else big like that that is probably about due?
thanks!
mixwhit is offline   Reply With Quote
Old 03-11-2008, 06:03 PM   #2
exbass94
exbass94's Avatar
Year: 2006, 1994
Make: Ford
Model: Ranger, Explorer
Engine: 4.0 SOHC, 4.0 OHV
Class: 4x4
Used For: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Send a message via AIM to exbass94
Default
The timing chain is supposed to last the life of the engine, no replacement necessary.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 45k miles
1994 Ford Explorer Sport 2-dr 4x4, 178k miles
exbass94 is offline   Reply With Quote
Old 03-11-2008, 06:04 PM   #3
reginald fairfield
reginald fairfield's Avatar
Year: 1999
Make: Ford
Model: Ranger
Engine: 3.0 liter FF
Class: 4x4
Used For: DD, Towing, Long trips
reginald fairfield is an unknown quantity at this point
Default
Replacing the timing chain at that mileage is a good idea, but I don't know if it is completely necessary. I would change all the fluids and oils including axles, flush the radiator, etc. I would also check things like the universal joints and wheel bearings for wear. Some motors will get completely destroyed if the timing chain snaps, I know that. I don't know if the 4.0 L is one of them.
__________________
Sir Reginald Fairfield III
1999 4x4 3.0 L, Rancho Shocks, Cranked Torsion Bars, Toolbox,Cobra CB, Custom pushbar made of 3/8 inch steel, Permanently locked hubs(ford and their damn vacuum )
Quote:
Originally Posted by gotmudd View Post
if you trade for the bird, he's gonna bend you over the hood and and #uck you in the ass, then he's gonna pull out and shove it in your mouth, BEFORE he wipes your shit off his dick. all of this figuratively[sp]
Quote:
Originally Posted by MAKG View Post
Threatening to shoot my "yuppiemobile" is very much over the line.
reginald fairfield is offline   Reply With Quote
Old 03-11-2008, 06:05 PM   #4
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Used For: a chicken house
Will is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to beholdWill is a splendid one to behold
Default
Forget about it. If it is running and the chains are quiet it's probably fine. If it isn't in a vehicle I would be suspicious, even if my mother were selling it to me. It's an overhead cam motor and it has a regular timing chain that goes from the crank to where the camshaft would be in a pushrod motor--but it's just a blank called a jackshaft in the 'cammer. Then, there is a timing chain in the rear for the right side cam and one in the front for the left side. If it is a 4x4 there is another chain that drives a balance shaft in the crankcase. All of those chains have nylon tensioners and guides. In earlier motors the guides dissolved and the motors started getting loud. In about 2001 or so I replaced a motor in a '98 Explorer that had finally had a chain fail. The owner of that truck could not get Ford to touch it out of warranty--the dealership mechanics did not know how to set up the timing at that time. So he drove it to failure and I put in a rebuild from one of those cheap places that paints over nasty shit with silver paint. At some point Ford had fixed the problem I would guess, but I wouldn't spend much money to find out if this motor is a quiet one unless you know first hand. There are no timing marks to line up and the chains sprockets on the cams are held with bolt tension: if you loosen one, the cam jumps and you'll never get it to run again. It takes special proceedures--probably involving a piston stop and a pair of degree wheels and a dial indicator or some neato kit that Ford developed for the techs.
__________________
'83 Ranger cab, '89 B2 frame, 4.0, C5, D35/8.8, 4.10s, Lockrights.
'87 Chevy crew 6.2 Banks turbodiesel TH400 GearVendors 4.10 14-bolt Detroit
'96 VW Passat Tdi
'00 Ford E350 15-pax Powerstroke
'09 Suzuki TU250X
'04 Moto Guzzi Breva
http://willwills.com/
Will is offline   Reply With Quote
Old 03-11-2008, 06:19 PM   #5
Muddycowboy
GOT MUD?
Muddycowboy's Avatar
Year: 2002
Make: Ford
Model: Ranger XLT
Engine: 4.0L
Class: 4X4
Used For: holding down jack stands
Muddycowboy is on a distinguished road
Default
check your local dealer for a maintance schedule they will be happy to print one out for you im sure
__________________
2002 ford ranger 4x4 stepside 4.0L manual,add-a-leaf, 3" shackle, 3" torq keys and T-crank,3" body lift,33x12.5x15 trxus mt's,JBA headers,cat delete, flowmaster40,dual 3" exhaust,cold air intake,jet performance chip,light bar,KC daylighters,custom bed cover,Cobra 29,2400 watt amp, 2 15" SUBS, 410 gears locked rear
Muddycowboy is offline   Reply With Quote
Old 03-12-2008, 07:35 PM   #6
07rangersport
07rangersport's Avatar
Year: 2006
Make: Ford
Model: F-150 XLT
Engine: 4.6
Class: 4x4
Used For: Work and Play
07rangersport is on a distinguished road
Talking
Quote:
I second that. If it was a timing belt......
07rangersport is offline   Reply With Quote
Old 03-12-2008, 08:15 PM   #7
Bruce
Bruce's Avatar
Year: 2002
Make: Ford
Model: Ranger Super Cab XLT
Engine: 4.0 SOHC
Class: 4x4 4:10 gears
Used For: Daily Driver
Bruce is on a distinguished road
Default
I have a friend who has a relative that works for FORD and when i bought my 2002 Ranger with the 4.0 he said that they have seen the chains fail at 70,000 miles. I dont know what year that was may of been an earlier model like 1 of the first years of the motor and he had a 1999 with 138,000 miles on it in his shop that he just got done changing the engine because of chain failure. I know of another 2000 4.0 that has150.000 on it and chains rattling and need changing and motor has to come out to change them from what i hear. Im not trying to scare anyone only stating what i have heard. The KEY factor of the whole deal is maintenance regular oil changes because of the ones i have heard of failing they had said where neglected and not maintained . I bought my truck with 43,000 miles on it and i have 71,000 on it now. Im not easy on a vehicle but i do change my oil every 6,000 miles and use nothing but full synthetic oil and i dont use the cheap filters either, most of my driving is highway
__________________
2002 Ranger Supercab 4x4 4 door 4.0 with 4:10 gears.
Bruce is offline   Reply With Quote
Old 03-12-2008, 08:55 PM   #8
Wicked_Sludge
Wicked_Sludge's Avatar
Year: 1993
Make: Ford
Model: Ranger, Flareside
Engine: 3-point-GO
Class: 4x4
Used For: Attracting the ladies
Wicked_Sludge will become famous soon enough
Send a message via MSN to Wicked_Sludge
Default
Quote:
the timing chain almost never fails....the 4.0 SOHC's weak link is the hydraulic timing chain tensioners. these fail quite a lot and cause the chain to fall off.
__________________
As seen on the internets!
Quote:
Originally Posted by Hahnsb2 View Post
Dyno sheet or GTFO
Quote:
Originally Posted by Ranger Dave (B25) View Post
The call was for scantily-clad women. A Certificate of Boob Authenticity was NOT specified.
Quote:
Originally Posted by Grant Imahara
I'm not sure if we have the right stuff; I'm just hoping we don't have the wrong stuff.
__________________________________________________ ____________________________________
Wicked_Sludge is offline   Reply With Quote
Old 03-12-2008, 10:33 PM   #9
reginald fairfield
Year: 1999
Make: Ford
Model: Ranger
Class: 4x4
Default
Quote:
What kind of noise do they make?
__________________
Old 03-12-2008, 11:38 PM   #10
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default
Chain rattling from the tensioners failing. I've never heard it--just cleaned up the mess afterwards. No worries with a 3.0 though.
This doesn't mean the 4.0 Cammer is a bad motor--far from it. It's a better motor than a pushrod 4.0. It just sucked while they were figuring out the correct receipe for the tensioner material. I drove that Explorer after I installed the new motor and it is a great motor. If you are used to a pushrod 4.0--it feels just like it, but it doesn't fall on its ass seconds after each shift. Those heads have huge ports that shoot straight down into the chambers--it's a hotrod motor and if someone told me the Mustangs were getting 250hp out of it, I would not be suprised. The only thing about it is it's size--it's HUGE compared to a pushrod 4.0. One thing I like about the pushrod 4.0 is the displacement density--a lot of cubes for such a compact size and it's a heavy-duty little bugger too. they don't fail from structural issues. They are big inside and tought for such a small package. The Cammer takes up a lot of space.
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Old 03-15-2008, 10:55 PM   #11
Will
Super Moderator
Will's Avatar
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4X4
Default
These are the parts required--
__________________
'96 VW Passat Tdi
'09 Suzuki TU250X
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
