Go Back   The Ranger Station Forums > Engine & Transmission Forums > Engine Conversions > V-8 Conversion Forums
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 04-28-2012, 07:17 AM   #25
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Make: All 10 are Ford
Model: Ex, Cobra, Ex, Ranger
Engine: 4.0,5.0,4BT,4.0
Class: none
Used For: Going places.
snoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond reputesnoranger has a reputation beyond repute
Default
Quote:
Originally Posted by alwaysFlOoReD View Post
The line that plugs into the slave also unplugs from the master. There is a roll pin that holds it in the master. You may be able to put the f-150 line into the ranger master but I don't know for sure.
Richard
Yup, they use the same fitting on the master end of the hose.
__________________
'95 Explorer -- EEC-IV SOHC swap. Now getting a "moderately built" 4BT Cummins, ZF, 4406, US Gear OD unit, 13" Cobra brakes, '99 Cobra wheels,....
4BT swap thread
Ranger bed trailer build
Scars are just tattoos... with better stories!
snoranger is offline   Reply With Quote
Old 04-30-2012, 05:12 PM   #26
MUDDING B-3000
MUDDING B-3000's Avatar
Year: 1997 , 1992
Make: Ford , Ford
Model: F-350 , Ranger
Engine: 7.3L , 4L
Class: 4x4
Used For: daily driver and weekend warrior!
MUDDING B-3000 is on a distinguished road
Default
alright im gonna get a hose for that n see if it works.
__________________
1997 Ford F 350 xlt 7.3L Powerstroke
1992 Ford Ranger 4x4 Full Width D44 an 9", 5.5 EB coils, custom extended RA's, custom leaf spring pack soon will be swaping in 5L .
MUDDING B-3000 is offline   Reply With Quote
Old 05-10-2012, 10:14 AM   #27
Diggerauditor
Junior Member
Year: 1988
Make: Ford
Model: Ranger Long Bed
Engine: 5.0
Class: 2WD
Diggerauditor is on a distinguished road
Default
Would a Mustang MC work, they come in sizes ranging from 3/4" to 1 1/8". Just chiming in cuz im getting rdy to do the same thing.
Diggerauditor is offline   Reply With Quote
Old 05-17-2012, 08:37 AM   #28
MUDDING B-3000
Year: 1997 , 1992
Make: Ford , Ford
Engine: 7.3L , 4L
Class: 4x4
Default
Alright well I got my stock ranger MC to work, I've bled n bled the system but I still can't get it into gears if you jiggle it n force it in it will go, an then the clutch engages right off the floor? Would my problem be I just need to bleed it more or? The slave cylinder if only 6 months old
__________________
Old 05-20-2012, 11:11 PM   #29
vince87ranger
Junior Member
vince87ranger's Avatar
Year: 1987
Make: ford
Model: ranger 5.5in lift lockers front and rear 4.10 gears 5 Speed
Engine: 5.0
Class: 4x4
Used For: dd wheeling, and money pit
vince87ranger is on a distinguished road
Default
this is exactly where i was, gave up on stock parts and bought a willwood 7/8 bore master and am in process of adapting it to the pedal right now. should be able to get it on the road sometime tomorrow with any luck.
vince87ranger is offline   Reply With Quote
Old 05-21-2012, 01:56 PM   #30
MUDDING B-3000
Year: 1997 , 1992
Make: Ford , Ford
Engine: 7.3L , 4L
Class: 4x4
Default
I might try buying a new MC cuz i know mines kinked abit n older so might be screwed. n if that doesnt work then maybe ive be swapping the whole trans out for a cable clutch 4 gear trans
__________________
Old 05-23-2012, 05:16 PM   #31
AllanD
RBV Technical Advisor
Year: 1987... sorta
Make: Ford
Model: Ranger Supercab
Engine: '93 4.0
Class: 4x4
Used For: Roadtrip Warrior
AllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to beholdAllanD is a splendid one to behold
Default
Quote:
Originally Posted by MUDDING B-3000 View Post
ok well i guess im just a retard ive been told that the ranger master cylinder will not work with the full size 5spd an ive read abit that they wont work, my stock ranger master will not click into the fullsize tranny slave cylinder to
What COLOR is the coupler on the end of the clutch line that you are trying to connect to the slave cylinder?
And what color is the coupler on the slave cylinder you are using?
There are TWO different RANGER mastrer cylinders, the 1983-92 Clutch master works with all, clutch slave cylinders that have the Black (fades to purple) or Red coupler. (this is the ALUMINUM slave cylinder)
IF the slave cylinder you have is the glass reinforced nylon plastic (Dupont trade name "Delrin") it will have a Gold/Yellow color and these require the matching master cylinder.
The Master you probably need was only used in Rangers and
Explorers 1993-94, and does not mount directly to the firewall,
it mounts via a metal mounting cup that it twist locks into.
the early master cylinder has an integral mounting flange made out of the same glass reinforced plastic the rest of the master is made out of.
While you can swap the lines this can cause problems, the early big bore
master cylinder used with the late "plastic" slave gives you a heavy pedal and quick clutch activation, but actually pushing the pedal to the floor can stress the firewall to the breaking point.
Doing the mismatch the other way results in a clutch that often cannot be bled properly and is hard to completely release.
as a side note the 1995-up uses a completely different master cylinder that doesn't mount to the firewall at all but directly to an ear on the pedal bracket.
AD
__________________
Gun Control - A theory espoused by some monumentally stupid people; who claim to believe, against all logic and common sense, that a violent predator who ignores the laws prohibiting them from robbing, raping, kidnapping, torturing and killing their fellow human beings will obey a law telling them that they cannot own a gun.
AllanD is offline   Reply With Quote
Old 01-17-2013, 01:21 PM   #32
Twister
Twister's Avatar
Year: 1985, 1987
Make: Duh
Model: Bronco II, Bronco II
Engine: 2.8L, 2.9L
Class: 4x4, 4X4
Used For: DD and occasional offroad
Twister is a jewel in the roughTwister is a jewel in the roughTwister is a jewel in the rough
Default
I know this thread is old, but i am trying to find out what clutch line to use. I am doing a 302 swap in an 85 B2, i am using an M5OD-R2 from an 02 v6 f150 and a master cylinder from an 89 ranger. So what year ranger or F150 clutch line do i want to use for no complications?
Twister is offline   Reply With Quote
Old 01-19-2013, 07:46 PM   #33
fordwheelinman
fordwheelinman's Avatar
Year: 1994
Make: Ford
Model: Explorer 4 door
Engine: 4.0L
Class: 4x4
Used For: DD
fordwheelinman is on a distinguished road
Default
AD
My 1994 explorer has a master cylinder that mounts directly to the firewall and it has two bolts that secure it to the firewall. So am i missing something, or is my 94 not really a 94 and someone has illegally swapped the vin plates?
__________________
*1994 Explorer 4 door- 4L ohv, FACTORY M5OD, working electric 4x4, new DD, awaiting 31x10.50's on black stock wheels
*1978 F150- 4x4, 400 V8, C6, 31x10.50x15 adventuro all terrains on stock steels-towing, 33x12.50x15 BFG All terrain on mag 15x8.5, custom in bed gooseneck, waiting on custom flatbed
*1989 Bronco II-Converted 4x2 to 4x4 with 2.9 bored .060, ported/polished heads, port matched manifolds, a4ld, man 1350, D28/7.5 4.10's in both L/S in rear: waiting on motor
fordwheelinman is offline   Reply With Quote
Old 01-19-2013, 10:22 PM   #34
snoranger
Boost Junkie
Tetris Champion
snoranger's Avatar
Year: 94,94,95,01
Class: none
Default
Quote:
AllanD is wrong (which doesnt happen often.). The 93-94 Explorer uses a bolt on clutch master... it is a little different from, and not interchangeable with, the 91-92 Ex, but they look similar.
__________________
4BT swap thread
Old 01-21-2013, 06:27 PM   #35
92ranger18
Year: 1992
Make: Ford
Model: Ranger
Engine: Stock 302
Class: Street
Used For: Putting Chevys out of their missery>
92ranger18 is on a distinguished road
Default
I used my 92 ranger master and an 89 trans. i think the R2 trans slave is the goldish color coupling. and the ranger is blue. i think or viseversa. i used the ranger master and spliced on the R2 coupling. but after i did that i realised i could have just punched the little pin out on both masters and put the R2 trans on the ranger master. for bleeding i gravity bled it by hanging the master resivor up and getting the hose as straight as possible, fill the resevoir with fluid and after it quits bubbling pump it up until you can barely push the rod. install it back in the truck and hook it all up then open the bleeder valve on the slave untill fluid runs out. run about one and a half resivoir fulls through it then it should be good to go. Sorry if it seems like alot.
92ranger18 is offline   Reply With Quote
Old 01-28-2013, 07:02 AM   #36
Diggerauditor
Junior Member
Year: 1988
Make: Ford
Engine: 5.0
Class: 2WD
Default
I just completed a swap that included an R1->R2. I used the R2 clutch slave cyl and clutch line with my orig MC. Bled easily, like brakes, and operates fine. A little stiff, considering it's pressing a V8 Pressure plate, but no sticking or hanging. Trans goes into first and reverse like normal. So I don't think there should be an issue unless there is a prob with the Slave or bleeding process.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
