Go Back   The Ranger Station Forums > TRS Photo & Video Galleries > Your Garage > Off-Road Rangers Under Construction
Notices
Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress.
Post New Thread Reply
Thread Tools Display Modes
Old 04-07-2012, 12:42 AM   #13
5speedin2.3
May 2012 OTOTM Winner
5speedin2.3's Avatar
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Used For: Daily driver/weekend warrior
5speedin2.3 is on a distinguished road
Default
its getting closer every day!
we got the rear done today and painted everything with primer. (after the pictures.)
__________________
1997 SFA Ford Ranger XLT, 2.5L, Black ext/Royal blue Int, Reg cab, Long bed, M5OD, 1354M, Jeep YJ D30 Front, 8.8 Rear, 4.10 gears, 33x10.50x15 BFG KM2's, Too much to list.
5speedin2.3 is offline   Reply With Quote
Old 04-07-2012, 12:44 AM   #14
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
SHOCKING NEWS!
got some super duty shock mounts today.
had to mod them a lil
plus we spray bombed everything
had to drill a top/third hole in the brackets after cutting them down.
next used some 1.5"x4" steel and made some spacer/mount brackets then welded them to the frame.
finished product
cheap curb flex
__________________
Old 04-07-2012, 12:44 AM   #15
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Looks good bud, nice 4x4 swap.
Only critique I got is grind everything down to bare shiny metal before laying any weld.
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is offline   Reply With Quote
Old 04-07-2012, 12:51 AM   #16
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
well i put the m/t's on, i cleaned the rims up with some 3m alloy polish, i think it did a great job.
then i went out and took some pictures behind a local store that has been closed down for years.
heres a before and after picture of the rims, two are alot cleaner, im not sure why, they almost seem newer.
i think chad should be happy to see im taking care of the rims.
before.
after.
[/QUOTE]
__________________
Old 04-07-2012, 12:57 AM   #17
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
All of those pictures are from 2008 and everything is still holding up.
Well, everything except the swaybar. I took that off over the winter because it broke.
More (newer) pictures will be up in a second.
All of those were copied from another forum where the mods are retards.
__________________
Old 04-07-2012, 01:05 AM   #18
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
I lied. More old pictures.
"well, i thought i would go take some new flex pictures.
i went as far as i could being 2wd with an open rearend and no parking brake. :squintfin
i was going to take the front swaybar links off but im lazy, so the flex is limited."
__________________
Old 04-07-2012, 01:12 AM   #19
Bennybooster
Bennybooster's Avatar
Year: 1996
Make: Ford
Model: Ranger
Engine: 3.0
Class: 4x4 offroad
Used For: Driving over stuff
Bennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to beholdBennybooster is a splendid one to behold
Default
I would flip your u-bolts so they don't hang down in the front
__________________
Built not bought
1 Ton, Caged Ranger build
Bennybooster is offline   Reply With Quote
Old 04-07-2012, 01:15 AM   #20
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
Quote:
Spring over axle?
Soon..
__________________
Old 04-07-2012, 01:29 AM   #21
n_bannerman
n_bannerman's Avatar
Year: 1986
Make: Ford
Model: Ranger 2.3L 4x4
Engine: 2.3
Class: 4x4
Used For: daily driver and occasional wheeling
n_bannerman is on a distinguished road
Default
Looking good! What year yj is the axle out of?
__________________
posted while ignoring work
86' extended cab 2.3 4x4 fender trim, rear factory block delete, 33x12.5 GoodYear Duratracs
My build thread http://therangerstation.com/forums/s...d.php?t=118614
n_bannerman is offline   Reply With Quote
Old 04-07-2012, 01:31 AM   #22
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
Oldest to newest.
__________________
Old 04-07-2012, 01:31 AM   #23
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
Quote:
94
__________________
Old 04-07-2012, 01:37 AM   #24
5speedin2.3
Year: 1997
Make: Ford
Model: Ranger XLT
Engine: 2.5L
Class: SFA D30 4X4
Default
New temporary exhaust setup.
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
