1354 fluid capacity
Bray D
2012 UA Ranger
OTOTM Winner
Solid Axle Swap
Manito, IL
how much fluid will my 1354 hold?
I need an amount so I dont over/under buy.
I buy by the gallon, and it's never taken the gallon.
lol we're gettin closer
IIRC 2.5 quarts. Buy 3.
they hold less than 2 quarts......right at about 1.75 quarts.....
I also seem to remember it being just under 2 qts (it's considerably less than the 2.5-2.75 qts the M5OD trans holds, I know)
Just buy three quarts, and if you have some extra, no biggie. Always good to have some around; Mercon goes in every damn orifice that Rangers have cept the motor.
What's absurd is that this datum is completely absent from the owner's manual... good job, FoMoCo... :rolleyes:
PS: You *CAN* put Mercon (Type F is better) in da motor... IFF you're within 500 miles of oil change. The detergent package in ATF is amazing at de-sludging and de-varnishing duh gasoline engine.
Olde thread, mah bad.
