Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 03-22-2012, 09:19 AM   #1
ranger1943
Vehicle Year: 1996
Vehicle Make: Ford
Vehicle Model: Ranger 2.3L
ranger1943 is on a distinguished road
Default Oil Pump Leak
I have a 1996 Ford Ranger 2WD 2.3L 4-cyl. I had a leak behind my timing cover and found that the oil pump was caked with grime, so I suspect that is my issue. I replaced the o-rings and the pump-to-block gasket and went to re-install the pump. I poured some oil into the pump prior to installation and noticed oil seeping from the weep holes. Is this a normal occurence while the pump is not installed in the motor? Or does this indicate a faulty pump? Thanks for your time.
ranger1943 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 03-22-2012, 12:11 PM   #2
chilsam
chilsam's Avatar
Vehicle Year: 91 branger
Vehicle Make: ford
Vehicle Model: hybryd swb ranger bod fs bronco chassis
I use this vehicle for: FUN!
chilsam is on a distinguished road
Default ???????
Quote:
The oil pump is at the bottom of the motor inside the oil pan do you mean the aux shaft?
chilsam is offline   Reply With Quote
Old 03-22-2012, 01:26 PM   #3
ranger1943
Vehicle Year: 1996
Vehicle Make: Ford
Default
Thanks for your response. No I mean the oil pump. On 95 and up 2.3L engines the oil pump is where the aux shaft is on 93 and 94 engines.
Old 03-22-2012, 05:49 PM   #4
chilsam
chilsam's Avatar
Vehicle Make: ford
Default I c
Old 03-24-2012, 09:14 AM   #5
ranger1943
Vehicle Year: 1996
Vehicle Make: Ford
Default
No one knows? I don't want to buy a $200 pump if I don't need one.
Old 03-24-2012, 12:54 PM   #6
scotts90ranger
scotts90ranger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
I use this vehicle for: holding down the driveway
scotts90ranger is a jewel in the roughscotts90ranger is a jewel in the roughscotts90ranger is a jewel in the rough
Default
the oil pump is in the oil pan on ALL 2.0/2.3/2.5L Lima engines, on '89 and up 2.3/2.5L Limas the auxiliary shaft only drives the oil pump. On a '95 you should have a cam sensor driven off of the auxiliary shaft somewhere, I haven't seen one in person that I've looked at but it should be there and is the only thing I can think of that you would be talking about, I'm with chilsam being confused...
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 03-25-2012, 08:44 AM   #7
4b316
Vehicle Year: 1995
Vehicle Make: ford
Vehicle Model: ranger
4b316 is on a distinguished road
Default
The oil pump on 95 and newer 2.3 and 2.5 ,s are on the front of the motor driven by the timing belt.43,are you saying that you are dumping oil on the pump itself before you put it in and its running back out the weep holes?if so,this is normal.it has to be installed to be sealed.Make sure you have good clean mating surfaces before you install.Rock auto parts have Melling oil pumps for $149 the last I looked.
4b316 is offline   Reply With Quote
Old 03-25-2012, 11:58 AM   #8
scotts90ranger
Vehicle Year: 1990
Vehicle Make: Ford
Default
ok, I stand corrected, just seems like a weird thing to change when leaving most of the rest of the block the same... never realized that, sorry
__________________
Old 03-25-2012, 01:06 PM   #9
Mark_88
Mark_88's Avatar
Vehicle Year: 2007
Vehicle Make: Dordge
Vehicle Model: Care A Van
I use this vehicle for: Space travel
My credo: Love Thy Neighbor
Mark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond reputeMark_88 has a reputation beyond repute
Default
Hey, now I know what that thing is...lol...I had to do quite a bit of searching to find it...good to know the oil pump is changeable without hauling the engine out of those ones...now I might narrow my search down a bit for a later engine...
__________________
Rome and my Ranger were not built in a day...
1988 Ranger 2.0 5 spd (gone)
1988 Ranger 2.3 " (gone)
1996 Ranger 2.5 (gone)
On-line manual link
http://www.therangerstation.com/foru...94#post1581294
Mark_88 is offline   Reply With Quote
Old 03-25-2012, 02:22 PM   #10
scotts90ranger
Vehicle Year: 1990
Vehicle Make: Ford
Default
Mark, you would have to run DIS with that style block if the oil pump is there, doubt there's a distributor drive if they changed that area...
__________________
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
