Go Back   The Ranger Station Forums > Styling & Electrical > Heating & Air Conditioning
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 03-04-2008, 03:06 PM   #1
gerry47c
Year: 1998
Make: mazda
Model: b4000
gerry47c is on a distinguished road
Default coolant in the oil
hi
b-4000 mazda 1998
I found coolant in the oil (look like greennish color and the oil level is too high). I want to know if a chemical product can do a good temporary job.
As I know, the problem is a gasket problem or a crack in the block.
help needed
gerry47c
gerry47c is offline   Reply With Quote
Old 03-04-2008, 04:37 PM   #2
MAKG
RBV Technical Advisor
Year: 1991
Make: Ford
Model: Explorer
Engine: 4.0L
Class: 4x4
MAKG will become famous soon enough
Default
Block sealer is quite unlikely to help and can make the repair more expensive (i.e., you may have to resurface the block, whereas this would otherwise not be necessary).
A cracked block is very unlikely unless you have substantially overheated it, or frozen coolant in the block. Cracked HEADS are considerably more likely. Before an overheat cracks the block, it's likely to scuff the cylinders, flatten the pistons, and seize the engine.
Running an engine with coolant in the oil will destroy it. Letting it SIT with coolant in the oil may destroy it. Crank and rod bearings don't like coolant.
__________________
1990 VW Jetta GL, 1.8L 8V gasoline engine, manual transmission, painted in oxidized red paint and ponderosa pine sap, unknown mileage.
1991 Exploder, 4.0L, M5OD-R1 manual transmission, electronic BW1354 transfer case, 3.54 gears, 31 inch tires, icky two-tone blue paint with little clear coat, 230K miles.
1972 Chevy C-10, 250 I-6, SM465 (2WD) four-on-the-floor, 3.73 gears in a GM 12-bolt, puke green with a white cab. The "4 wheeled trash can," with x70K miles. x is probably 2.
MAKG is offline   Reply With Quote
Old 03-04-2008, 10:15 PM   #3
Sasquatch_Ryda
Coast Mountain Crawlers
Sasquatch_Ryda's Avatar
Year: 1991/1997/2008
Make: Ford
Model: Ranger/Ranger/SuperDuty
Engine: 4.0L/3.0L/6.4L
Class: 4x4
Used For: Play toy/Daily Driver/Grocery Getter
Sasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to beholdSasquatch_Ryda is a splendid one to behold
Send a message via MSN to Sasquatch_Ryda
Default
Coolant in the oil will make a murkey whitish color in the oil, gasoline in the oil on the otherhand will look somewhat greenish/brown. Was the oil very thin?
__________________
http://www.coastmountaincrawlers.com
1991 Ranger - one tons, 3 link, air shocks and 40's
1997 Ranger - reg cab flare side, 3.0L, M5OD-R1, 4x4, 4.56 gears, 6" lift, 33" MT's.
2008 F350 - 6.4L Powerstoke Diesel, 35x12.50R18 Procomp Xtreem AT's on 18x9 Incubus Crushers, AFE DPF/DOC Delete pipe, H&S XRT Pro tuner, AFE Stage 2 intake
1967 Mustang Coupe - 289, c4, pretty much stock
Sasquatch_Ryda is online now   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
