| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#109 |
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8
Class: 4x4
Used For: "sparked", carbed, TK5, 1350, 215's
Rep Power: 7 ![]() iTrader: (0)
When I intially got the OMC intake was a Holley/Weber 5200 (32/36) which I have one of. In making an adapter I was going to effectivley make a 1" high thick fabbed spacer. I actually have a 1" thick spacer for a 5200 and it seems to be recommended for a power increase. A 1" spacer/adapter basically (not prepared for the OMC), but if Were going to make an adapter It would be up to 1" thick..or more actually I think
In fact to use a 2GC I would make a 1" adapter to raise it up for flow Last edited by John Smith; 04-03-2012 at 11:02 PM. |
Tweet
#110 |
Ok guys, I talked with Esslinger today. On their recommendation, I got the 1" spacer here- # E2740
http://www.esslingeracing.com/catalog305/page17.pdf I also bought a Holley 350, refurbished by Holley for $230 (good buy, I think). To go on the EFI intake. So, I have an OMC intake (D-port) to sell. Drew has first right of refusal if he wants it back. Other than that, I'll sell it on Ebay |
Tweet
#111 |
Einstein I'm NOT
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Rep Power: 76 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
I'd be interested in the intake if I could afford to swap out the parts...but I think my intake will take a Holley 350 as a direct bolt on...and it comes with an adapter...
I'm sure it will be gone fast if Drew doesn't want it back...hopefully I can find one if I decide to swap out mine... Anyway, looks like your build is coming together fast...hope you have plenty of pics...
__________________
Rome and my Ranger were not built in a day... |
Tweet
#112 |
The engine pieces are coming together -LOL!
A friend works at Frymaster and is making the "decklid". At least one thing will look professional ![]() We still have the fab work in getting the engine mounted, running the water pipes and many other little things I probably haven't thought of. I did remember I need a water temp. gauge now. I'll have it mounted and wires ran before we get that far.. If Drew doesn't want the OMC intake back, I can hold it for you for a while if you want it. |
Tweet
#113 |
Einstein I'm NOT
Year: 1988
Make: Ford
Class: 2wd
Thanks...might be quite a while before I have any disposable cash...but, who knows...lol
__________________
Tweet
#114 |
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8
Class: 4x4
I finally decided to take my OMC / Rochester carb number to my parts guy and realized it actually is a 2GE, the "E" being for an electric choke version. This carb #17086107 actually belongs to correctly to a marine application for a Cobra "140" inboard/outboard motor. Since I have the manifold..I think I will kit in time and mount it all up for an auto application on this .040 motor I have built. Not being a GM guy for many years..I've been outa touch with the Rochester stuff, but they have a long automotive history..we'll maybe see how it comes together... At least this carb is correctly sized for a 140 cu motor..something which you can only guess about with some other options.
For any of you who would like to run this carb on your "air-sled" in a marine application I still have the "spark-arrester" carb cover..(humor) To those of you who rebuild your own carbs, may I recommend a guy you can order parts from and actually catch him on the phone once in a while...and parts are actually "made in the USA...when they can be still found.. http://www.carburetor-parts.com/product_p/4082.htm Last edited by John Smith; 04-04-2012 at 08:51 PM. |
Tweet
#115 | ||
Junior Member
Year: 1984
Make: Ford
Model: Ranger XL (Long bed)
Engine: 2.3L
Class: 4x4
Used For: Project - Off-road
Rep Power: 3 ![]() iTrader: (0)
Quote:
Quote:
Tweet
#116 |
Year: 1988
Make: Ford
Model: Ranger XLT SuperCab
Engine: 2.3
Class: 2wd
Used For: Everything
Rep Power: 12 ![]() iTrader: (0)
This is the adaptor I used to put a Holley 2bbl on the OMC intake manifold. http://www.summitracing.com/parts/TRD-2086/
__________________
For all you need to know see the Updated 2.0, 2.3, 2.5 engine family, click on the link below. http://www.therangerstation.com/foru...d.php?t=124928 |
Tweet
#117 | |
Quote:
If so, that looks like something I could use on my other engine- the 2.0 out if the Ranger- and then, I'd have a complete spare. Last edited by itlives; 04-05-2012 at 11:58 AM. |
Tweet
#118 | |
Year: 1988
Make: Ford
Engine: 2.3
Class: 2wd
Quote:
Yep the OMC intake with a 350 Holley carb I get 22 mpg in the city, 26-27 mpg on the hwy.
__________________
Tweet
#119 |
That sounds great to me. I'll run it with the EFI intake and see what my MPG is (it'll be awhile). I'll go ahead and get that adapter you mentioned. I could have 4 of them for what Esslinger charged for the one I got! (Wish you'd have posted earlier
)EDIT- I just went back and looked at that adapter. It says it's for the Rochester 2 GC. So, that means it has the same base as the Holley 350, right? Last edited by itlives; 04-05-2012 at 06:06 PM. |
Tweet
#120 | ||
Junior Member
Year: 1984
Make: Ford
Engine: 2.3L
Class: 4x4
Quote:
Quote:
Sorry man that sucks, looks like you fell victim to the same thing as bigpanda in that situation… A little update on my project… I bought an oval port “Z” type intake manifold that I plan on using… My next step was finding an oval port cylinder head. I found a guy that said he can get whatever one I needed to, just to take a picture of the intake I am looking for and email it to him. He also said that he would install a roller cam setup as well. I send him an email stating that I was looking for an oval port 2.3 (‘74-‘80), and wanted to clarify that it would come with the roller cam setup as he originally stated. I sent him the picture of the oval port cylinder head that Kenneth posted earlier in this thread. He wrote me back and said “I do not have any three journals, haven’t seen any for years”. My first question is, aren’t they all 4 journals? My second is, does anyone know of anywhere I can get the oval port head I am looking for? I can only seem to find the D port heads available. If I can’t get a oval port head, my options will be a D port cylinder head, or rebuilding my Ranger round port. ![]() Either way it would mean if I went with the D port head, I would need to get another D port intake, and the oval port “Z” intake would be useless to me… OR ![]() I would have to rebuild my round port cylinder head, and then would need to find a intake manifold like the 2.0 2-barrel, and would have to start looking into carburetor options again… ![]() I would much rather just be able to find an oval port head, I really appreciate any help guys! |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
