| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
#85 |
Year: 1988
Make: Ford
Model: Ranger XLT SuperCab
Engine: 2.3
Class: 2wd
Used For: Everything
Rep Power: 12 ![]() iTrader: (0)
I never put any type of sealer between the rear bearing cap, and the block, and never had any major leaks. The most I've seen is just a very minute amount of seepage between them.
__________________
For all you need to know see the Updated 2.0, 2.3, 2.5 engine family, click on the link below. http://www.therangerstation.com/foru...d.php?t=124928 |
Tweet
#86 |
I did go and look in my Chilton manual . It says to put a little sealant there, but it's showing a two-piece seal. My engine has a one-piece seal.
I don't think it would hurt to take off that one cap and put some RTV there but I'm going to wait for my friend to come over this weekend and see what he says. He used to dirt-track these engines so I'm guessing he'll know. One other thing, another reason I'm changing engines is I can't stand oil leaks. The VW's leak so much the VW peeps say they don't leak, they just mark their spot. I'm tired of oil leaks, adjusting valves and generally having to baby this VW along. I'm hoping the 2.3 (with all new everything) and no EMPI parts(Empi = Chinese =yucky crap!) will mean happy driving! Edit- One more one more thing, earlier I posted the weight of my truck as almost 5000 lb.s. I was wrong. It is 2650. The 5K is fully loaded. So, with proper gearing and tires, I should get some good MPG! Last edited by itlives; 04-26-2012 at 09:42 AM. |
Tweet
#87 |
Year: 1988
Make: Ford
Engine: 2.3
Class: 2wd
Putting a just a little bit of sealer there wouldn't hurt.
P.S. The EMPI stuff wasn't that good 20 - 30 years ago.
__________________
Tweet
#88 |
Einstein I'm NOT
Year: 1988
Make: Ford
Model: Multi-year Ranger
Engine: 2.3 Carbureted
Class: 2wd
Used For: Space travel
Rep Power: 76 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (0)
Pics...can't wait to see this...and before you try burning the tires off I hope you give it a good break in...I've heard 100 km and change oil...then 2500 and change it again...what is your plan on that or what do you recommend?
__________________
Rome and my Ranger were not built in a day... |
Tweet
#89 |
I break in the cam (this is from VW experience) by running the engine at between 2,000- 2,500 RPM for the first 20 minutes. Shut down the engine. Check for any leaks. Change the oil. Run for 500-600 miles. Change the oil. Then change oil normally.
Is it usually done different on these engines? |
Tweet
#90 | |
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8
Class: 4x4
Used For: "sparked", carbed, TK5, 1350, 215's
Rep Power: 7 ![]() iTrader: (0)
Quote:
http://forum.turboford.org/cgi-bin/u...031;p=0#000001 Quote..."Yes towards the outer corners...if you look at the main cap, you will see the corner that mates with the corner in the block is not square.... So there is a little triangle shaped channel that leads from the crank case to the outside of the block on the left and right sides of the main cap.... Guess what people think is leaking oil...the main seal when its really the main cap. Just enough to leave a silver dollar sized drop every time you park and drive you (me) nuts..... My current motor is 99.99% leak free and I am now 99.99% sane....." another quote.. Originally posted by johnk&triumph: Its the corners that leak not the two mating surfaces. When you look at without silicone, you can see day light.....through the two corners... I will post a pic when I get a chance. jk Looked at a bare block and main cap; I see what you're talking about now. The Chilton manual specifically adresses this issue. But I couldn't find it mentioned anywhere in the in the 1987 or 1992 Ford manuals. Maybe its addressed separately in a Ford TSB. This post is a conversation about turbo'd motors., but any crankcase pressure will cause some leaks... I hope it goes well for you..good project Last edited by John Smith; 04-26-2012 at 12:41 PM. |
Tweet
#92 |
Einstein I'm NOT
Year: 1988
Make: Ford
Class: 2wd
Yeah, looks like something I need to read over and check...thanks John!
__________________
Tweet
#94 | |
Year: 1984
Make: Ford
Model: Bronco II
Engine: 2.8
Class: 4x4
Quote:
I would remove the cap..seal it and re-torque myself. |
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
