| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Southern Midwest Members KS,MO,OK,AR,TX,LA,MS |
| View Poll Results: Where are you wanting to go? | |||
| Texas Hill Country |
0 | 0% |
| K-Trail |
5 | 100.00% |
| Voters: 5. You may not vote on this poll | |||
Thread Tools | Display Modes |
#109 | |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 2WD Off-Road
Used For: truckin around
Rep Power: 31 ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() iTrader: (7)
Im trying to get together some kind of list of who is going and who is on the fence just so we have a general idea. I'll add it to the first post. If i miss someone or someone or anything just post it up and I'll update the list. Currently it stands as:
ATTENDING sbsrlewis daniel3507 MAYBE Country0001 BroncoIIer kryptonitecb Transmarobirdeater tandangerranger If the name is in italics its just because we haven't heard from them recently
__________________
Quote:
Build Thread (click) 1993 Ranger XLT 4.0, 20% tint, 2'' spacers, RS9000XL adjustable front shocks, Bilstein rear shocks, 4.10 gears, 31'' tires, 15'' Alcoa's, custom front shackles, Lvl II rear tow hook, 2.25'' exhaust w/ Super 44, Screamin' Demon coil pack, slotted rotors w/ EBC Greenstuff, Delta Cam rockers and pushrods |
Tweet
#110 | |
gravel in my travel
Year: 1990,92
Make: Ford,Ford
Model: B2,F150
Engine: 4.0,5.0
Class: 4x4, 4x4
Used For: tearin up the gravel roads
Rep Power: 14 ![]() ![]() iTrader: (7)
Will anyone have a cookstove?
__________________
Quote:
Tweet
#111 | |
Year: 1993
Make: Ford
Model: Ranger XLT
Engine: 4.0
Class: 2WD Off-Road
I don't have one but may be able to borrow one.
Sent from my LS670 using Tapatalk
__________________
Tweet
#112 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
Used For: Play and daily driver
Rep Power: 12 ![]() iTrader: (1)
This list is from Sam's Offroad website. Items with asterisks (*) are items I already have. Items with numerical sign (#) I plan to get before trip. Items with dash (-) are items I probably won't have.
Remember these are just "Recommended" Trail Gear. * 30' Tow Strap * Front and Rear Tow Points * Tire Plug Kit/Spare Tire/Jack * Fire Extinguisher * Tire Air Deflators/Tire Gauge # First Aid Kit * Trash Bags * Ice Chest-Lunch/Keep Hydrated * Bug Spray/Sun Screen/Hat * CB * Tool Kit/Pliers/Screw Driver Steve
__________________
1989 BII, 4.0, Mazda 5-Speed, 1350/1354 Doubler, D-35 w/D-44 outers, 8.8 w/Yukon Ultimate 88 kit and disk brakes, 1" BL, JD Coil Buckets, 66-77 F150 Coils, JD HD Coil Seats, JD front quad shocks, JD Extended Radius Arms, Extended Braided Stainless Steel brake lines, Cut fenders, 33" Pro Comps, Line-X'd interior & rocker panels. Last edited by sbsrlewis; 02-08-2012 at 05:58 AM. Reason: added dash |
Tweet
#113 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
This list and the following ones are taken from a past 4 Wheel and Offroad article.
The following is a "B-4 U GO" checklist. Check these items so you may avoid making some repairs in the rocks or mud: * Engine Oil * Transmission Fluid * Brake Fluid * Hydraulic-Clutch Fluid * Transfer-Case Oil * Differential Oil * Power-Steering Fluid * Belts * Grease all driveshafts, U-joints, and Steering joints * All Lights and Turn Signals * Windshield-Washer Fluid (helps clean off mud) * Radiator Coolant level * Tow hooks (front and rear) of your vehicle * Tire pressure and look for leaks or gashes * Check for loose parts: Lug nuts, drive-shafts, engine and tranny mounts, suspension joints and U-bolts And last - Tell someone where you are going and when you'll be back Steve
__________________
1989 BII, 4.0, Mazda 5-Speed, 1350/1354 Doubler, D-35 w/D-44 outers, 8.8 w/Yukon Ultimate 88 kit and disk brakes, 1" BL, JD Coil Buckets, 66-77 F150 Coils, JD HD Coil Seats, JD front quad shocks, JD Extended Radius Arms, Extended Braided Stainless Steel brake lines, Cut fenders, 33" Pro Comps, Line-X'd interior & rocker panels. Last edited by sbsrlewis; 02-08-2012 at 05:50 AM. Reason: Giving credit for the list and following lists. |
Tweet
#114 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
BARE NECESSITIES - Bring this stuff and some ingenuity and you will get ou of may trail mishaps:
* A buddy with either a history in long-distance running to go get help or his own 4x4 * Duct tape * Bailing wire * Zip-ties * WD-40 * Ratchet strap (reseat tires, helps strap parts in place) * Tow strap * Leatherman type utility tool and/or Swiss army pocketknife # Piece of 1/4" or larger chain 4' long (goo for fixing suspension and motor mounts) * Warm jacket # First aid kit # Jug of water # Granola bar or candy bar * Fire extinguisher # Flashlight # Matches/lighter Steve
__________________
1989 BII, 4.0, Mazda 5-Speed, 1350/1354 Doubler, D-35 w/D-44 outers, 8.8 w/Yukon Ultimate 88 kit and disk brakes, 1" BL, JD Coil Buckets, 66-77 F150 Coils, JD HD Coil Seats, JD front quad shocks, JD Extended Radius Arms, Extended Braided Stainless Steel brake lines, Cut fenders, 33" Pro Comps, Line-X'd interior & rocker panels. |
Tweet
#115 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
WHAT WE ALWAYS BRING - If we're goig wheeling for the day, this is a good list of tools and stuff to bring:
* Tool bag containing: -Screwdrivers (3 different sizes) -Pliers (Dikes, needle-nose, channel locks, snap ring, adjustable, locking) -Hammer (ball-peen) -Wrenches (standard and metric - we bring both, you decide what you need) -Adjustable wrench -Sockets (standard and Metreic - we bring them, but often wrenches are enough) * Spark plug socket * Pick tools (handy for fixing hubs) * Test Light * Prybar * Jack of some sort (High-Lift, bottle, or floor-depending on the terrain and size vehicle) * Tire repair kit * Electrical tape * Allen wrenches * Hacksaw Steve
__________________
Tweet
#116 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
PERSONAL STUFF - Theses items will make the trip more enjoyable:
* Toilet paper * Sunscreen * Bug spray # Food and water (no, beer doesnt' qualify as water) * Extra jacket * Rags/towels Steve
__________________
Tweet
#117 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
SPARE PARTS - These parts start adding weight, but it's better than the long walk home:
- Tie-rod end or Heim joints (spherical rod ends) for steering - Heim joint for your custom linked suspension * Engine belts - Front axleshafts - Rear axleshafts - Front axle U-joints - Driveshaft U-joints * Spare tire - Spare locking hub or set of drive flanges - Spare bolts of commons sizes found on your truck # Fuses for you truck (some fuse panels have spaces to store spares) - Radiator hose # Hose clamps # Electrical crimp kit * Valve cores - Lug nuts Steve
__________________
Tweet
#118 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
LUBES - Different goo to help you go:
* Oil * Power-steering fluid * Brake fluid * Automatic-transmission fluid * Gasoline or diesel # Form-a-gasket or RTV silicone to reseal gaskets # Water * Gear oil * WD-40 Steve
__________________
Tweet
#119 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
CAMPING GEAR - Basic stuff for staying in the dirt:
* Warm clothing and rain gear # Tent or good tarp - Camping stove and fuel * Sleeping bag and pad * Cooler Steve
__________________
Tweet
#120 |
Year: 1989
Make: Ford
Model: Bronco II
Engine: 4.0
Class: 4x4
BONUS STUFF THAT WE LIKE HAVING ALONG - Many of you get along without these, but they are very useful, especially if you need to do extreme trail repairs:
- Air compressor or CO2 thank - Impact gun and impact sockets - Underhood welder Steve
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
