Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 09-12-2011, 08:49 PM   #1
Ranger22danger
Vehicle Year: 1994
Vehicle Make: Ford
Vehicle Model: Ranger 2wd 2.3ltr
Ranger22danger is on a distinguished road
Default Wont start but turns over!!
so got a question i have a 1994 ford ranger 2wd 2.3 litre and it is turning over but not starting... Would that be eletric ignition or my coil packs?
I just replaced the timing belt, water pump, and all the top end gaskets. The timing marks are spot on so it is not my timing. It is not getting any spark... I need help cause i am stumped it seems like this thing has ghosts in it hahaha!
Ranger22danger is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 09-13-2011, 05:14 PM   #2
Plum Ranger XLT
Vehicle Year: 2008
Vehicle Make: Ford
I use this vehicle for: Daily Transportation
Plum Ranger XLT is on a distinguished road
Default
Possible coil packs or fuel pump went out.
__________________
2008 Ranger 2.3L DOHC 4 cylinder 5 speed and will only own Ford!
Plum Ranger XLT is offline   Reply With Quote
Old 09-13-2011, 05:39 PM   #3
Cadger
Junior Member
Cadger's Avatar
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: driving, moving scrap, fun!
Cadger is on a distinguished road
Send a message via MSN to Cadger Send a message via Skype™ to Cadger
Default
If it's not getting any spark, make sure you have your crank sensor plugged in. The coils won't fire without a crank reference.
__________________
'94 ranger XL 4x4 ext cab, running 32/11.5r15 on factory rims, 2" lift blocks, and nothin else really! OH! it's PURPLE!
Purple POWER!
Cadger is offline   Reply With Quote
Old 09-13-2011, 05:59 PM   #4
cody93
cody93's Avatar
Vehicle Year: 1987,1987
Vehicle Make: FORD, duh
Vehicle Model: rANGER x2
I use this vehicle for: scaring yuppies on the interstate
cody93 has much to be proud ofcody93 has much to be proud ofcody93 has much to be proud ofcody93 has much to be proud ofcody93 has much to be proud ofcody93 has much to be proud ofcody93 has much to be proud ofcody93 has much to be proud of
Default
yea, i agree with the CPS being off, especially since timing belt work was done.
__________________
Quote:
Originally Posted by gwaii View Post
anything will fit.i have a sawzall and a welder.
Quote:
Originally Posted by AllanD View Post
Once upon a time it was financially practical to ship dirty laundry to China to have it washed rather than wash it in San Francisco.
cody93 is offline   Reply With Quote
Old 09-13-2011, 11:51 PM   #5
scotts90ranger
scotts90ranger's Avatar
Vehicle Year: 1990
Vehicle Make: Ford
I use this vehicle for: holding down the driveway
scotts90ranger is a jewel in the roughscotts90ranger is a jewel in the roughscotts90ranger is a jewel in the rough
Default
if it's a california model with a cam sensor and you didn't keep the auxiliary shaft aligned that could do it too...
so it was running fine and you replaced those parts and now it suddenly doesn't start? Sounds like something got unplugged or something in the process...
__________________
converted to 4x4, turbo'd the 2.3, 6" lift with 35's and 5.13 gears!
Send e-mail instead of PM, box full...
scotts90ranger is offline   Reply With Quote
Old 09-14-2011, 01:13 AM   #6
Bryan22
Bryan22's Avatar
Vehicle Year: 94 extd
Vehicle Make: Ford
I use this vehicle for: fun, dd.
Bryan22 is on a distinguished road
Default
Cam sensor shouldnt keep it from starting, but you can unplugg it to be sure(If it's a cali model). definitely make sure all 3 screws are in the ICM, the crank sensor it plugged in and not damaged, and that all conections are good to the ICM and coil packs... Good luck.
Bryan22 is offline   Reply With Quote
Old 09-15-2011, 04:34 PM   #7
Ranger22danger
Vehicle Year: 1994
Vehicle Make: Ford
Default
I think this truck has ghosts because right before i bought it from my dad he had just dumped like 800 bucks into it because it started to run funny and so he took it to the shop and while the mechanic was looking at it. the truck just dies and they couldnt get it running for two weeks. And the other day i was driving down the road at 55 mph and it just died on me. I pulled to the side of the road turned the key off and then fired it back up. then about a week later it I went to a friends house it was driving great no problems, and that was the last time i have got to drive it well unless you count towing it like 20 miles so i could get it home. So i think i am going to just buy a 4.0 carburated motor and not worry about it no more
Thank you guys for all the answer
Old 09-16-2011, 12:50 AM   #8
Bryan22
Bryan22's Avatar
Vehicle Make: Ford
Default
you should just fix the problem and drive it for another 100k miles. Nothing is that complicated really. Shit, for $800 bux I could just guess an answer by replacing parts... thats nuts.
Old 09-16-2011, 03:07 AM   #9
ChargerOnDavins
ChargerOnDavins's Avatar
Vehicle Year: two 2003, 1 200
Vehicle Make: 3 Ford & 1 Dodg
Vehicle Model: Ranger, Explorer, Charger
ChargerOnDavins is on a distinguished road
Default
Fuel pump - one of fords weak points. Still rather own 1 ford to 5 chevy or 10 dodge.
ChargerOnDavins is offline   Reply With Quote
Old 09-16-2011, 01:53 PM   #10
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
Quote:
-if it it's a cali model it should have an obd-ii port and no ICM
-these trucks are pretty simple, if you are not able to figure it out i doubt very much you would have the skills to drop in a carbed 4.0 and get it running.
-I am confused about whether it ever ran after the TB install
-I am confused if you have spark or not........next time this happens determine if you have spark and or fuel
-I am not sure what they were doing for 2 weeks maybe they were using as a free parts delivery truck. I am a back yard mechanic and I bet I would have this figured out in less than an hour.
-relay? key cylinder? ignition switch?
-any CEL or pending codes?
__________________
2004 Ext Cab, 4WD, 4.0, Auto, 153k(engine is out of a 2009 Ranger with 95k) Mileage readings as of 5/14/2017
2004 Ford Ranger Edge, Ext Cab, 2WD, 3.0, 5 speed, 116,000, AC. (SOLD)
1999 Ford Ranger, Reg Cab, 2.5, 5 speed, 2WD, no AC, 150k (SOLD)
modelageek is offline   Reply With Quote
Reply
Bookmarks
Tags
1994 ranger 2.3 litre
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
