Go Back   The Ranger Station Forums > Truck Discussions > Fullsize Trucks > Fullsize Chevy/GMC Trucks
Notices
Post New Thread Reply
Thread Tools Display Modes
Old 05-14-2012, 08:14 AM   #25
RangerSVT
Oct 09 OTOTM
RangerSVT's Avatar
Year: 1996
Make: Ford
Model: Ranger SC 4x4
Engine: GT-40 5.0L EFI W/AC
Class: 4x4 EXTREME DD
Used For: Anger Management
RangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to beholdRangerSVT is a splendid one to behold
Send a message via Yahoo to RangerSVT
Default
Usually when you have a milky substance in the engine, its from a blown head gasket or cracked head. I was not aware of the Intakes prone to leaking coolant. Guess it shows I'm not familiar with gm engines
SVT
RangerSVT is offline   Reply With Quote
Old 05-14-2012, 09:55 AM   #26
Josh40601
Josh40601's Avatar
Year: 1991/1994ish
Make: Ford
Model: Explorer/Ranger
Class: stock-ish....
Used For: depleting savings accounts
Josh40601 has a spectacular aura aboutJosh40601 has a spectacular aura about
Default
I thought the same thing as you brother. This is a whole new animal here. I'm learning though. Evidently, these engines have condensation that is very typical to find minimal amounts of water within the intake and throttle body. They have a catch can kit that eliminates this, which is the next thing on the upgrade list as long as the heads are ok
__________________
Sgt Ex Mall Crawlin Trail Limo
De-Ranged March 2011 OTOTM
The Legacy of Whopper Jr
1MeanC10 68 C10
My 1st Ranger November 2010 STOTM (Gone but not forgotten)
Josh40601 is offline   Reply With Quote
Old 05-14-2012, 09:57 PM   #27
dieseldane
Premium Member
dieseldane's Avatar
Year: 1984/1995
Make: Ford
Model: Bronco 2/Fordenstein
Engine: 2.8/5.0
Class: 4x4
Used For: DD/taking up garage space
dieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud ofdieseldane has much to be proud of
Default
The intakes on these don't have any coolant passages in them, so that's not the issue... Even if they did, his oil isn't milky, so there's no coolant leaking into the crankcase, and the coolant would enter the intake long after the throttle body and just get sucked into the cylinder, far away from the trottle body.
EDIT: What I'm thinking is, if anything you might have an excessive amount of crankcase pressure due to bad rings or blown head gasket, blowing too much oil vapor through the PCV, mixed with condensation entering through the air intake, to give you that milky crap you're seeing.
I'd do a compression and leakdown test before anything else.
dieseldane is offline   Reply With Quote
Old 05-15-2012, 09:10 AM   #28
Josh40601
Josh40601's Avatar
Year: 1991/1994ish
Make: Ford
Default
The pressure relief line running from the heads to the upper radiator hose was capped off, and I think was a large contributor to this.
Also remember the engine only has around 70-75k on it now. I bought it with 68k (or so they said. It was a company specializing in LS1 takeouts, so I don't see why they would lie. Especially considering what I paid for it)
__________________
1MeanC10 68 C10
Old 05-15-2012, 10:46 PM   #29
dieseldane
Premium Member
dieseldane's Avatar
Year: 1984/1995
Make: Ford
Engine: 2.8/5.0
Class: 4x4
Default
Pressure relief line? Mind taking a pic of what's capped off/where it is and putting it up? Are we talking oil pressure relief? crankcase pressure? Not sure what you are describing but neither of those would be attached to any coolant hose. Might be able to help ya figure out if it's anything that will be causing your issue.
And although your motor might not have many miles on it, unfortunately doesn't mean they've been easy going miles.
Old 05-16-2012, 07:12 AM   #30
Josh40601
Josh40601's Avatar
Year: 1991/1994ish
Make: Ford
Default
Here are the pics.
This is the line that is capped off as you can see in the pic. It runs through the throttle body to actually heat up the air. You can bypass this, but the line it connects to via the rubber line shown, needs to be routed into the cooling system. this is where it attaches to the heads.
It's a crossover line that runs from the heads through the TB, into the radiator. Mine never ran to the radiator, so pressure would build right there backing coolant that should be going to the radiator into who knows where
__________________
1MeanC10 68 C10
Old 05-16-2012, 12:42 PM   #31
dieseldane
Premium Member
dieseldane's Avatar
Year: 1984/1995
Make: Ford
Engine: 2.8/5.0
Class: 4x4
Default
Ok yeah that is a steam vent, and it does need to go somewhere.
Check out this link, posts #7 and #9:
http://www.camaros.net/forums/showthread.php?t=168401
That does need to be fixed, but that isn't what's causing the extra oil in behind the throttle body. Like you said before, the moisture in there causing the oil to turn milky is just moisture being pulled in through the intake. The extra oil is from one of two things: simply just a bad PCV valve, or over-pressurization of the crankcase. The latter you could check to find the cause of by doing a leak down test, to make sure that the pressure isn't leaking past your rings, a blown head gasket, or a cracked head.
Old 05-16-2012, 01:58 PM   #32
Josh40601
Josh40601's Avatar
Year: 1991/1994ish
Make: Ford
Default
I have a hydrocarbon leak test kit here, but I can't use it until the truck can run. So I have to install the line before I can pressure test it.
Edit:
I also already have the line, just waiting on the adapter that goes in the radiator hose to button everything up.
Any idea where to get torque specs for valve cover and water pump bolts?
__________________
1MeanC10 68 C10
Old 05-16-2012, 03:47 PM   #33
dieseldane
Premium Member
dieseldane's Avatar
Year: 1984/1995
Make: Ford
Engine: 2.8/5.0
Class: 4x4
Default
Anything to test your coolant system won't really do you any good, as it's not the problem.
The problem has nothing to do with your cooling system, or anything leaking into it.
EDIT: The pressure I am talking about is coming from within the combustion chamber, and leaking into an oil passage, or past the rings, not the coolant system.
I'll find ya some torque specs tonight.
Old 05-16-2012, 04:09 PM   #34
Robert_1967
Robert_1967's Avatar
Year: 1988/1989
Make: Ford
Model: Ranger Supercab/BroncoII
Engine: 302/2.9
Class: 2wd Street/4x4 street
Used For: Soon to be hot rod/Daily Driver
Robert_1967 has a spectacular aura aboutRobert_1967 has a spectacular aura about
Default
my friend has a 48 chevy truck that has a LS1 in it, those lines off the head need to go back in to the top of the rad, or somewhere near the top.
Robert
Posted from my Dell in the year 3015 and sent back in time.
__________________
All Truths are Known upon Death.
If I can't work on my Ranger or BroncoII, I rather be fishing.
If Facebook, MySpace, and Twitter were all destroyed, 90% of teens would go insane.
Robert_1967 is offline   Reply With Quote
Old 05-16-2012, 04:28 PM   #35
dieseldane
Premium Member
dieseldane's Avatar
Year: 1984/1995
Make: Ford
Engine: 2.8/5.0
Class: 4x4
Default
Quote:
Robert
As long as they are vented anywhere into the coolant system higher than their mounting points on the heads, it's fine.
The purpose of those lines is this: since there are no coolant runners going across the intake manifold, the corners of the heads become the highest point of the coolant system within the engine itself. If it were not for those lines, air and steam would become trapped in the heads, which in turn would mean that no coolant could circulate at the very least where the air was, creating hot spots in the heads, and potentially warping them or worse, cracking them. So, it doesn't matter what you plumb that line to, be it the radiator, a heater hose, or your upper radiator hose, as long as it is higher than the head and allows the air to escape.
Old 05-16-2012, 09:14 PM   #36
Josh40601
Josh40601's Avatar
Year: 1991/1994ish
Make: Ford
Default
It's being ran to the upper radiator hose. I now know it shouldn't be capped.
Thanks to all you guys who are helping! Who knew you could get answers related to a Chevy on a hardcore Ford website?! It's ok. I only own 1 Chevy. And this is it. Best body style and best engine the Bowties ever made.
__________________
1MeanC10 68 C10
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
