Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 08-16-2011, 07:13 AM   #1
rick01cay2010
Vehicle Year: 1984
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: offroad
rick01cay2010 is on a distinguished road
Default Rear disc brake conversion
How can I change my 1984 ford ranger drum brake to disc brake. What do I need for part's.
rick01cay2010 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 08-16-2011, 08:56 AM   #2
Downey
Vehicle Year: 1994
Vehicle Make: ford
Vehicle Model: ranger
I use this vehicle for: everything
Downey is on a distinguished road
Send a message via AIM to Downey
Default
you need an explorer 8.8 with disc brakes is the easiest way to do it
__________________
94 ford ranger
4.0 5 spd with 260k
Twin Sticks and 31s
straight pipes
Downey is offline   Reply With Quote
Old 08-16-2011, 09:21 AM   #3
AgPete139
09/2014 OTOTM Winner
AgPete139's Avatar
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger XLT Xcab
I use this vehicle for: DD, hauling stuff, & getting me everywhere a car can't
AgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to beholdAgPete139 is a splendid one to behold
Default
Downey, that would require switching all of the outers, along with the new 31 spline axles and housing/carrier. He has a stock 7.5, so he cannot just switch them. (If that's what you meant.)
Otherwise, Rick, get a 1996 Explorer axle on up. I remember the 1995 were dumb in some way, so dont worry about that year. You would need to cut, remount, and weld the shock tabs and the spring perches. You might as well rebuild the axle seals and bearings if you think it's a shoddy-looking axle. Recut rotors and new pads are also a necessity.
__________________
Green Ranger Build:
1997 Ranger Ext 4.0L 5spd BW1354M, ~7" lift Deaver springs & Explorer leaves, front D44 welded 4.88, rear Expo 8.8" autolocker, 35x12.50x15 KM2's, 1.25" DOM front bumper, shock towers + buckets, communication & stereo bits
ADD YOURSELF TO THE TRS MEMBERS MAP !!!
http://www.therangerstation.com/foru...d.php?t=128467
AgPete139 is offline   Reply With Quote
Old 08-16-2011, 09:25 AM   #4
Downey
Vehicle Year: 1994
Vehicle Make: ford
Default
i have one in my truck swap the whole axle reason i said get an explorer 8.8 the whole axle
__________________
94 ford ranger
4.0 5 spd with 260k
Twin Sticks and 31s
straight pipes
Old 08-16-2011, 09:51 AM   #5
rick01cay2010
Vehicle Year: 1984
Vehicle Make: Ford
Default
I would like to keep my stock axle. If I do change to a 8.8 axle from a explorer, what year should I look for?
Old 08-16-2011, 09:56 AM   #6
Downey
Vehicle Year: 1994
Vehicle Make: ford
Default
96 or newer
__________________
94 ford ranger
4.0 5 spd with 260k
Twin Sticks and 31s
straight pipes
Old 08-16-2011, 09:18 PM   #7
stmitch
March 2011 STOTM Winner
stmitch's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
I use this vehicle for: Surprising people
stmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of lightstmitch is a glorious beacon of light
Default
The explorer disc brake axles are nearly 3 inches wider than the stock asle in squarebody trucks if that matters to the OP.
The other option is to add mustang discs to the stock axle. You'll need the backing plates, discs, and calipers. You can reuse your hardline, but I shortened it, and added custom braided stainless lines instead. You can probably get everything you need from a junk yard for pretty cheap. If you want new parts (Ford Racing sells a kit with everything but the calipers), it'll probably cost $400-$500 depending on if you get cobra rear discs, or just GT discs.
stmitch is offline   Reply With Quote
Old 08-17-2011, 12:32 PM   #8
rick01cay2010
Vehicle Year: 1984
Vehicle Make: Ford
Default
If I decide to go with the mustang kit, would my 15" rim fit? There's a kit for 185.00$ without the caliper from a 1994-2004 mustang, would it fit my 1984 ford ranger stock 9" axle
Old 08-17-2011, 12:42 PM   #9
Boggin
Boggin's Avatar
Vehicle Model: 89 bronco ii
I use this vehicle for: going inappropriate places
Boggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to beholdBoggin is a splendid one to behold
Send a message via AIM to Boggin Send a message via MSN to Boggin
Default
Quote:
Originally Posted by rick01cay2010 View Post
I
Wanna bet?
__________________
05 F250 - 6.0, 6 speed, deleted by RCD, SCT tuned, blue spring, sinister coolant filter, dummy plugs/stand pipes, Atlas 80 ficm, afe intake, 4" turbo back straight to 5" mitre cuts, 6" lift with rear air bags, 35" pro comps
04 Ranger 4.0 4x4 - stock
02 Duramax - afe intake, Super chip, straight pipe
93 W 250 12v cummins - stage 5 fuel pin
Lots of past rbv's
"Dont know how to drive automatic"- Chance. RIP Buddy.
Boggin is offline   Reply With Quote
Old 08-17-2011, 02:49 PM   #10
stmitch
stmitch's Avatar
Vehicle Year: 2000
Vehicle Make: Ford
Default
The GT brakes would definitley fit your 15's. The Cobras would be alittle close. I fit my stock 15's on the rear with Cobra brakes once just to check, but it was WAY close to rubbing on the caliper. This is all assuming that you don't have a 9 inch rear since Ranger's never had a 9 inch from the factory. The kit I've mentioned (probably the same one you're looking at) can be used on either the 7.5 or 8.8 rears since the axle flange is the same on both.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
