Go Back   The Ranger Station Forums > Truck Discussions > General Discussions
Notices
General Discussions This forum is for general discussions. Place posts that don't fit in any other forums here.
Post New Thread Reply
Thread Tools Display Modes
Old 06-17-2011, 10:53 PM   #1
mps617
mps617 is on a distinguished road
Default Ford ranger suspension woes
So my friend recently got 2001 Ford Ranger. We couldn't find anything wrong with it besides the shocks were a bit soft... But as we are driving it at higher speeds on the highway (especially in downtown boston) some bumps will make the truck feels uneasy and it's very unsafe in my opinion. So we are replacing his shocks of course. The other issue is there is a lot of play in the steering wheel. It's very easy to move back and forth about an eighth turn each direction. Could it be because of the shocks?
mps617 is offline   Reply With Quote
Old 06-18-2011, 12:18 AM   #2
BRUTUS_T_HOG
BRUTUS_T_HOG's Avatar
Year: 89
Make: Ford
Model: Ranger S
Engine: 2.3L
Class: 2WD Street
Used For: everything
BRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of lightBRUTUS_T_HOG is a glorious beacon of light
Default
the steering issue won't be caused by shocks... and since a 2001 should have rack and pinion steering that amount of play is excessive.
jack up the truck and see if you can find play in the steering linkages which would be the inner and outer tie rod ends
also check the wheel bearings by grabbing the tire at the top and bottom and pushing in and out.. then do the same grabbing the sides of the tire.
if you find nothing there look for a worn steering coupler which would be at the base of the steering column under the dash or where it couples onto the steering rack... if you find no slack there replace the steering rack.
BRUTUS_T_HOG is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
