Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Help Forums - Engine & Transmission Forums > Transmissions
Reply
Thread Tools Display Modes
Old 06-02-2011, 08:39 PM   #1
TorkTek
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger
TorkTek is on a distinguished road
Default New 2 4um.. Need info about 3.0 Vulcan bellhousing pattern
Is it common with any other Fords like maybe the 2.3 or something? I have a 93 Ranger 2wd and if I have to keep it, I certainly want to toss the 5-spd and it's clutch. My third clutch in it now is toast, howling badly when letting out the clutch. I would like to use a good old dependable C-4/C-5 automatic as i can rebuild those and don't want to fool around with an A4LD. I would much rather build and r&r 2 or 3 C-4's, than to try and weild that beast 5-spd in and out once to put another clutch in it. What is the heritage and when was the 3.0 (or whatever it was at first) originally used in Fords, pintos, couriers or whatever?? What vehicle can I look for to get the auto trans i need? Knowledgeable help is greatly appreciated.
TorkTek is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 06-02-2011, 11:23 PM   #2
masterbrenden
masterbrenden's Avatar
Vehicle Year: 1998/2010
Vehicle Make: ford/ford
Vehicle Model: ranger/ranger sport
I use this vehicle for: everything and then some
masterbrenden is on a distinguished road
Default
http://www.therangerstation.com/tech...rformance.html
read this... it will answer you questions
__________________
98 xlt 3.0l at 4x4 2 inch lift 255/70/16 now bent
10 ranger sport. 4.0 sohc a.t. 4x4 (very loaded)
Quote:
Originally Posted by kaytbugsdad View Post
(Welcome to California, please leave your balls at the front gate!!!!!!)
masterbrenden is offline   Reply With Quote
Old 06-03-2011, 04:53 AM   #3
exbass94
exbass94's Avatar
Vehicle Year: 2006, 1994
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Pavement Poundin'
exbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really niceexbass94 is just really nice
Default
The only other RWD vehicle the 3.0 was ever used in was the Aerostar, which also used the A4LD. The 3.0 was also used in the Taurus and Windstar, but those are both FWD vehicles so obviously those transmissions wouldn't work. Those are the only vehicles I know of that ever used the 3.0.
__________________
2006 Ford Ranger Sport 4x4 2-dr Extended Cab, 63k miles
1994 Ford Explorer Sport 2-dr 4x4, 203k miles
1992 Honda Accord EX, 182k miles
1994 Ford Bronco XLT (project)
2014 Subaru XV Crosstrek, 33k miles (wife's)
exbass94 is offline   Reply With Quote
Old 06-03-2011, 11:51 AM   #4
TorkTek
Vehicle Year: 1993
Vehicle Make: Ford
Default 3.0 bellhousing pattern is it's own one of a kind....?
seems wierd that ford would do that.. Maybe I can look up part numbers for spacer plates between trans and motors...
Old 06-03-2011, 10:45 PM   #5
TorkTek
Vehicle Year: 1993
Vehicle Make: Ford
Default
If I can't find a trans I guess it may wind up as a 302/C-4 replacement and since the bed is now ruined. I'll have to build another flatbed (w/cherry picker this time). 108"wb a/c p/s 8.8 3.73LS. Two tone with caymen green or accap blue on top and that gold crap color on the bottom......Will have to build a fence around the bed to keep retards from jumping on and off while I try to drive....
Old 06-11-2011, 10:18 PM   #6
orangealpine
Junior Member
orangealpine is on a distinguished road
Default
The 3.0 bell pattern is the same as the old "Pinto" 2.0. That does not help much as there are few trannys for that one still floating around, but the C4 was used. It is very similar to the 2.3 pattern. The two top bolts are in a different location and the locating pins are different diameter. Stepped locating pins are easy to make and some guys run with only four of the six bolts. Others have filled the bell housing and drilled holes to match the engine.
Bill
orangealpine is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
