Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 02-12-2008, 07:35 PM   #1
addiman09
addiman09's Avatar
Vehicle Year: 2003
Vehicle Make: Ford Ranger
Vehicle Model: 2.3 Liter 5spd
I use this vehicle for: everything
addiman09 is on a distinguished road
Default ECU Chip for 2.3L ranger
Do they make a ecu chip for the 03 2.3L ranger, i only ask because i can only find chips from edge, which i was referred to, but their lowest liter is 6.0 powerstrokes, any help
Thanks
addiman09 is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 02-13-2008, 02:30 PM   #2
DemonC
Vehicle Year: 2003
Vehicle Make: Ford
Vehicle Model: Ranger
DemonC is on a distinguished road
Default Answer, but more questions...
The only real way to add torque/horsepower to the 2.3L Duratecs is with a tuner and custom tunes. I have been researching this topic for a while now and have narrowed my search down to two providers.
bamachips seems to be the one that has done the most research with the 2.3L, and I've read a lot of good things about the results seen with their tunes. The problem is that their customer service has apparently gone down the pooper recently. I've read numerous posts on different boards about difficulties contacting them. One customer reported waiting more than three weeks for his tuner to arrive, and many complain about lack of response to e-mails. They do not list a phone number on their website.
RoguePerformance has wonderful customer service, but I'm not sure how much research they've done with the 2.3L as they seem to be more focused on other engines. Apparently you receive your custom tunes, log some data with the tuner, and then they will tweak them for you for the first week... but I may have misunderstood this, and I have reservations with this technique versus working with a dyno to achieve the tunes.
The real question is this. If custom tunes give you more torque in a real-world usable range (1500-3500rpm), more horsepower and better mpg, then why aren't they tuned this way from the factory?
Any input to any of this would be greatly appreciated.
Cheers
DemonC is offline   Reply With Quote
Old 02-14-2008, 10:34 AM   #3
addiman09
addiman09's Avatar
Vehicle Year: 2003
Default
Well the only reason i ask, is to remove the governor part and move the rev limiter back farther, do u know if they do that??
Reply please
Thanks
Old 02-14-2008, 12:21 PM   #4
DemonC
Vehicle Year: 2003
Vehicle Make: Ford
Default
They will.
Old 02-14-2008, 01:16 PM   #5
addiman09
addiman09's Avatar
Vehicle Year: 2003
Default
alright man thanks, this is gonna help me alot, my truck topped out a 90 in 4th gear at 4000 rpms.
Thanks again, addison
Old 05-10-2008, 03:27 AM   #6
W04RFR
W04RFR's Avatar
Vehicle Year: 2004
Vehicle Make: FORD
Vehicle Model: RANGER
W04RFR is on a distinguished road
Default
What times were you doing?
W04RFR is offline   Reply With Quote
Old 05-22-2008, 12:29 PM   #7
addiman09
addiman09's Avatar
Vehicle Year: 2003
Default
none i was just driving on the highway
Old 05-22-2008, 04:38 PM   #8
BroncoV6
Vehicle Year: 1993
Vehicle Make: FORD
Vehicle Model: RANGER 5-SPEED
BroncoV6 is on a distinguished road
Default MAF Modification
I tried cleaning the heater wire on the MAF sensor and it seemed to help. I used CRC Contact cleaner. I also noticed that the sensor was almost totally blocked off on the backside (the intake manifold side). It looked to me like the wire could not get air across it to make the computer know what the actual temp of the air flowing over the heater wire was. The cover on the back side of the MAF is aluminum so I bent the bottom part of the cover straight out so that more air could go thru the hole that the wire is in. This modification made a slight improvement in take off power and highway power. I still get the same MPG as I did before.
From what I understand the heater wire in the MAF cools slightly when air flows over it. The cooling changes the resistance of the wire and the computer uses that information to adjust the timing and/or fuel delivery to the injectors.
I can send you pics of the modification if you want.
hardyboy@hughes.net
BroncoV6 is offline   Reply With Quote
Old 05-23-2008, 10:02 AM   #9
addiman09
addiman09's Avatar
Vehicle Year: 2003
Default
yeah that would be great, im looking to get more speed, i know its zippy, but i beat a 300zx off the start and then lost due to top speed
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
