Home | Ford Ranger Forum | Builders Guide | How To Tech | Other Articles | Featured Rangers | Readers Rangers | Classifieds | Shirts & Decals |
#1 |
Vehicle Year: 1997
Vehicle Make: mazda
Vehicle Model: B2300
I use this vehicle for: daily driver and want to turn it into a street strip racer
Rep Power: 0 ![]() |
hey guys i currently have a 97 mazda B2300 manual trans. and i want to know if there is a direct bolt on positive traction rear end like out of a 4x4 ranger or mazda that i can put under it so i can race a little i am currently putting a new clutch and wanting to put a turbo or nitrous on it any specifics answers would be greatly appreciated i was told that i could possibly just put the gears and axles out of a 4x4 in the rear end i have but i have no idea about rear ends at all and what i can do
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member. |
#2 | |
Rep Power: 22 ![]() ![]() ![]() ![]() |
__________________
Quote:
#3 |
Vehicle Year: 1997
Vehicle Make: mazda
so does that link basically say i can put a locker in my 2wd truck to simply make it a positive traction rear end????/
#4 |
07/2014 OTOTM Winner
Vehicle Year: Title says 84.
Vehicle Make: Furd
Vehicle Model: Hey! is that a stubby Ranger?!
Nope, it's a B2.
I use this vehicle for: getting onto rbv forums.
Rep Power: 24 ![]() ![]() ![]() ![]() ![]() ![]() |
i bought this mini spool from jegs for $79.
#5 |
Mall-Rated
Vehicle Year: 1990,1994
Vehicle Make: Ford
Vehicle Model: Bronco II, Ranger
I use this vehicle for: Crawling over things
Rep Power: 10 ![]() ![]() ![]() ![]() ![]() ![]() ![]() |
If you're after an actual locker of some sort, the Aussie Locker or LockRight might be what you're looking for. It simply replaces the spider gears in your stock open diff carrier.
If you'd rather have a limited slip (aka "Posi"), swapping the entire axle for a salvage yard axle with a factory L/S is generally the easiest route (you could install a L/S diff into your existing axle too, though this usually requires messing with the gear setup, which is pretty tedious work).
__________________
'90 Bronco II XLT 5" lift (Skyjacker Jeep coils), D35 & 8.8" w/5.13s (locked), 1354 dual T-case, 35x12.50s '94 Ranger XLT 6" Skyjacker, ARB D44 front, Detroit 8.8" rear, Atlas 4.3, 33s |
#6 |
Vehicle Year: 1997
Vehicle Make: mazda
well i am just interested in getting both wheels turning for better grip im gonna start running it at the drag strip on the weekends a little and like i said rear ends are foreign to me so what would be the best and easiest way to do it???
#7 |
Vehicle Year: 1997
Vehicle Make: mazda
what does the mini spool do rico????
#8 |
Vehicle Year: 1997
Vehicle Make: mazda
i have a 89 ford bronco the big one not the bronco ll will the rear end from it fit under the ranger
#9 |
Vehicle Year: 1998/2006
Vehicle Make: Ford/Nissan
Vehicle Model: Ranger/Altima sedan
I use this vehicle for: Causing Trouble/Commuting
Rep Power: 17 ![]() |
A spool basically replaces the spiders and locks up both wheels so they always turn at the same speed. Some people "lincoln lock" up the spider by sinkiing some welding rod into the spiders and lock them up that way, but if you're looking to drag, get a spool. If your Bronco has an 8.8" axle it will fit but requires a bit of modification to the axle to accept the Ranger's springs and shocks.
__________________
MBRP Off-Road Pro Cat-Back Shorty Exhaust/ '00 Stepside bed conversion/ 5" rear flip kit |
#10 |
Vehicle Make: Furd
Nope, it's a B2.
replaces the spider gears and locks the rear full-time.
Bookmarks |
Tags |
b2300, positive traction, rear end |
Thread Tools | |
Display Modes | |
