Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 04-08-2011, 07:12 PM   #21
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
escort_gts's Avatar
Vehicle Year: 1993, 2001
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Daily Driver
escort_gts is a jewel in the roughescort_gts is a jewel in the roughescort_gts is a jewel in the rough
Default
Got a present today at my front door....
Motive 4.56 and Motive master kit and also got a solid pinion spacer so I dont have to use the crush sleeve. The solid spacer is nice when setting these up, if you make a mistake and need to take it apart, you don't have to get another crush sleeve.
My uncle works for National Drivetrain in chicago and he got me a good deal on the parts...
escort_gts is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 04-08-2011, 07:44 PM   #22
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Just ordered new U-bolts from RuffStuff. Should be here next week. I now will have everything I need to get this build underway. Should be starting it within two weeks if all goes as planned.
Old 04-09-2011, 02:22 AM   #23
dangerranger83
5.0 HO under the hood!!!
dangerranger83's Avatar
Vehicle Year: 1983
Vehicle Make: Ford
I use this vehicle for: My DD, play toy
dangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud of
Send a message via Skype™ to dangerranger83
Default
Now I know who to hit up when I need to get gears.
__________________
Build thread, 5.0 swap happening now!!!! Click me
5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear.
dangerranger83 is offline   Reply With Quote
Old 04-14-2011, 09:15 PM   #24
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Starting the r&p swap tomorrow if all goes as planned. I will take pictures along the way for everyone...
Old 04-14-2011, 09:28 PM   #25
bobbywalter
RBV Technical Advisor
bobbywalter's Avatar
Vehicle Year: 1988
Vehicle Make: FORD
Vehicle Model: RANGERISH SORT OF THING
I use this vehicle for: EVERYTHING
My credo: it is easier to fix and understand than "her"
bobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to beholdbobbywalter is a splendid one to behold
Default
had the last few of mine done with solid spacer when i had 8.8. had issues with yokes staying tight.
__________________
88 ranger ext cab low rider 4x4 propelled by 395 cubes of of non turbo SLOBBERIN DIESEL...BLAHHH...motating a 4l80 thats AUTHORITATIVELY turnin a ford 208 spinning 410 open dana 60s and whatever tire suits the mood that day. how ya like me now?
bobbywalter is offline   Reply With Quote
Old 04-14-2011, 09:31 PM   #26
Bray D
2012 UA Ranger
Bray D's Avatar
Vehicle Year: 1996
Vehicle Make: Ford
I use this vehicle for: quenching my thirst for adventure.
Bray D will become famous soon enoughBray D will become famous soon enough
Default
I'd rather setup my gears with a crush sleeve anyways. Much easier to sneak up on the preload than to torque it down - wrong preload - take it apart - new shim stack - torque it down - wrong preload - take it apart - new shim stack - repeat repeat repeat.
bobby - go check your pm's on rrorc.
__________________
'96 ranger - narrowed HP D44, ChroMo shafts, geared/locked, hi-steer - 31 spline 8.8, dutchman shafts -1350/1354 doubler - 37's on TR beadlocks.
Petersen's 2012 Ultimate Adventure Invited Reader
Bray D is offline   Reply With Quote
Old 04-15-2011, 12:19 AM   #27
RacinNdrummin
RacinNdrummin's Avatar
Vehicle Year: 2005
Vehicle Make: Ford
RacinNdrummin is on a distinguished road
Default
Ive done a couple of 8.8's with the shim packs and I havent had a problem. Set it up, torque it, and forget it. If you use the thickness of the previous crush sleeve as a starting point, its a hell of a lot easier to get the preload right the first time. Both times for me, the thickness of the crush sleeve was perfect and I didnt have to pull it back apart. Id do a shim pack way before Id ever do a crush sleeve again, much easier...
__________________
-05 ranger 2wd 3.0 M5OD
-90 BII/4.0 SOHC-EEC-IV/M5OD/1354m/D35/Welded 8.8/Mutt lift/34"LTB's/Navajo Front clip...http://www.therangerstation.com/foru...ad.php?t=35258
RacinNdrummin is offline   Reply With Quote
Old 04-15-2011, 10:46 AM   #28
Josh40601
Josh40601's Avatar
Vehicle Year: 1991/2001
Vehicle Make: Ford
Vehicle Model: Explorer/Ranger
I use this vehicle for: depleting bank accounts
Josh40601 has a spectacular aura aboutJosh40601 has a spectacular aura about
Default
oh how i love some 3rd gen SASes
__________________
D-Ranged The never-ending project
Sgt Ex An old explorer with a bunch of dents
My 1st Ranger November 2010 MTOTM (Gone but not forgotten)
Josh40601 is offline   Reply With Quote
Old 04-15-2011, 11:00 AM   #29
dangerranger83
Vehicle Year: 1983
Vehicle Make: Ford
Default
And they are better when being converted from 2wd to 4wd.
__________________
Old 04-15-2011, 06:34 PM   #30
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
If for some reason the pinion depth is not right and have to take it apart and add a shim, then the crush sleeve is not useable anymore. So that is why I choose to use the spacer instead of the sleeve. Also, if you have to change a pinion seal, then you dont have to take the whole diff apart to change the crush sleeve.
I ran out of time today to finish the gear change. Got it all torn apart and on the assembly side now. Here are some pics, it's hard to take pictures with dirty oily hands so I tend to forget to take them untill I am done...
I might need to get some new axle bearings soon...
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
