Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Go Back   The Ranger Station Forums > Truck Discussions (Not for tech help - Use Help Forums further down) > 1983-2011 Off-Road & 4x4 Ford Ranger's
1983-2011 Off-Road & 4x4 Ford Ranger's Show of your trucks, or post your build threads. This is NOT a help forum. Post your questions in the Help Forums further down
Reply
Thread Tools Display Modes
Old 05-08-2011, 06:58 PM   #101
escort_gts
02/2012 04/2013 04/2014 OTOTM Winner
escort_gts's Avatar
Vehicle Year: 1993, 2001
Vehicle Make: Ford
Vehicle Model: Ranger, Explorer
I use this vehicle for: Daily Driver
escort_gts is a jewel in the roughescort_gts is a jewel in the roughescort_gts is a jewel in the rough
Default
Quote:
Originally Posted by kroussinoffroad View Post
just remember if you adjust your trac bar you'll need to adjust your steering as well.
yep. Want to get all that done before i go to get it aligned.
escort_gts is offline   Reply With Quote
Advertisement (Not shown to 'Premium Members')
Old 05-08-2011, 07:44 PM   #102
dangerranger83
5.0 HO under the hood!!!
dangerranger83's Avatar
Vehicle Year: 1983
Vehicle Make: Ford
I use this vehicle for: My DD, play toy
dangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud ofdangerranger83 has much to be proud of
Send a message via Skype™ to dangerranger83
Default
Does this mean you will have to make a new drag link since you have to shorten your track bar or do your TRE's have enough threads in them?
__________________
Build thread, 5.0 swap happening now!!!! Click me
5.0 HO carbed, np435 with an np208 transfercase, 32 inch BFGoodrich M/T's, D30 SAS with 6.5 XJ coils, 63 inch leaves in rear.
dangerranger83 is offline   Reply With Quote
Old 05-08-2011, 08:03 PM   #103
Kyle M.
GOING FOR BROKE
Kyle M.'s Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: driving over stuff
Kyle M. will become famous soon enoughKyle M. will become famous soon enough
Default
I would weld it to the frame. You don't need it to come off and if you do you can cut it. Bolt and weld, then gusset to the engine cross member
__________________
93 RANGER/CLOSE TO STOCK/
www.CheapThrillsOffRoad.com
Kyle M. is offline   Reply With Quote
Old 05-08-2011, 08:41 PM   #104
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Quote:
There are plenty of threads, I made the draglink about 3/4" shorter than the stock XJ draglink.
Quote:
Ok, weld it to the frame. Should I fabricate a new one or just modify what I have? I didn't get a chance to take a pic of it. Got to dark out and if I took it with the flash on my phone it would not turn out. This is a pic from the 89 but it is the same on the 93.
Old 05-08-2011, 08:49 PM   #105
ChrisR1S
10/2013 STOTM Winner
ChrisR1S's Avatar
Vehicle Year: 1994
Vehicle Make: Ford
ChrisR1S is on a distinguished road
Default
Awesome and quick build man! On the trackbar bracket, I definitely agree that it needs to be bolted/ welded to the bottom of the frame to eliminate the flex.
__________________
1994 ranger 4x4- 33s, long arms, 4.0- the never ending rebuild
2007 ranger 2wd- djm 4/5-the dd soon to be powered by eaton
1995 ranger that lays rocker-bagged, body dropped, fully shaved, lots of tweed
1997 ranger- stripped shell waiting for a build plan
ChrisR1S is offline   Reply With Quote
Old 05-08-2011, 08:57 PM   #106
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Quote:
Yeah, looking at the above pic I see that is what needs to be done. I will have to take it off weld some plate to the bottom to bolt to. Then weld the whole thing to the frame....
Old 05-08-2011, 09:43 PM   #107
disciplerocks
July 2011 OTOTM Winner
disciplerocks's Avatar
Vehicle Year: 1989
Vehicle Make: Ford
Vehicle Model: Bronco II XLT
I use this vehicle for: the rippin and the tearin
disciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to beholddisciplerocks is a splendid one to behold
Default
Holy Sheet!!! I come back to this thread after a few days and the damn thing is done
__________________
89 Bronco II XLT: 4.0, A4LD/5R55E, 1354 Doubler, 35" Baja Claws, XJ coils, FW HP44, Tru-Trac, Spooled FW 8.8 Disc Brake, 4.56s, OBA
94 F150 XLT: 5.0 HO, OBDII, E4OD
04 Focus ZX3: Built 5.0, T5, 4 lug 7.5, Rear Discs, 3.73s
12 Focus SE: Sport & Winter Package, ST Front End
Quote:
Originally Posted by AllanD View Post
Ford says (about towing not masterbation) "Don't do that!"
disciplerocks is offline   Reply With Quote
Old 05-08-2011, 09:48 PM   #108
Kyle M.
GOING FOR BROKE
Kyle M.'s Avatar
Vehicle Year: 1993
Vehicle Make: Ford
Default
After seeing it, looks to me if you made your brace flatter to the ground and weld that to the engine crossmember and leave it bolted to the track bar mount, I bet that would help out the most if you want to keep it removable. But honestly, plate the bottom and weld it to the frame would be the strongest. I would still keep your tie in at the engine crossmember and make it flatter or perpendicular to the track bar mount.
__________________
Old 05-08-2011, 09:52 PM   #109
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
The 93 is a little more perpendicular than the 89, but not by much.
Old 05-08-2011, 10:02 PM   #110
escort_gts
escort_gts's Avatar
Vehicle Make: Ford
Default
Quote:
Yeah, I don't mess around.
Actually I had to get it done asap because it is my daily driver and I had 3 days off to work on it.
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
