| Home | Forums | Info - Technical | Info - Other | TRS News | Photo Galleries | Shirts & Decals | Parts Store | Classifieds |
| Off-Road Rangers Under Construction Share your off-road Ranger projects here so we can follow the progress. |
Thread Tools | Display Modes |
#13 |
November 2012 OTOTM Winner
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Used For: getting away from the kids
Rep Power: 5 ![]() iTrader: (0)
Well since I moved my axle forward about 4 inches from the original location my stock steering box wasnt going to cut it. It would end up in the radiator unless I dropped it down. So I decided to use a fj60 box with a trail queer ifs pitman arm reamed out to accept 1 ton chevy tie rod ends. I had to do quite a bit of surgery to the frame rail to get this done. Special thanks to mr. plasma cutter.
__________________
90 ranger 5.0 dana 44 60 rear c4 203/20 cases on 4d's |
Tweet
#14 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Well since I moved my steering box on the outside of the frame my trackbar just needed to get alot longer. So I drew up some templates out of card board and built a trackbar bracket that moved the mounting location over in front of the passenger coil spring.
![]() Some heims from ruff stuff for the track bar. ![]() Heres a toyota pitman arm and tapered reamer for 1 ton chevy tierod ends. ![]() ![]() ![]() And I have to give Swag offroad a plug for this radius tool for a plasma cutter sweet tool. And yes I know my welding skills are lacking but Im sure nothing will come off.
__________________
Tweet
#15 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
I got it sitting on its own weight brackets burned in I know the axle bracket is a little ugly but it isnt going to break. My next project is to get the tranny rebuilt in the next couple of weeks and transfercases installed again. Yes I know none of the nuts are tight or have cotter pins.
__________________
90 ranger 5.0 dana 44 60 rear c4 203/20 cases on 4d's Last edited by RANGERROD; 08-14-2011 at 09:23 PM. |
Tweet
#16 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Well I got 3 of my tires so I mounted them with the help of my 16 month old son.
__________________
Tweet
#18 |
Year: 1997
2006
Make: ford
Model: ranger
f 150
Engine: 4 litre and 4.2 litre
Class: 4x4 ranger 2wd f 150
Used For: ranger was rolled... working on rebuild. the f150 is for a dd and towing
Rep Power: 18 ![]() ![]() ![]() ![]() ![]() iTrader: (1)
i hate to say it but those are on backwards.. ive got the same tires and the more luggy part should be to the outside.
at least thats my understanding
__________________
97 ext cab 4x4 483'000km 33" duratracs 1" washer spacer "minor" fender trimming R.I.P 91 f350 cc/lb on 35s 88 lwb sammi toyota 22re on 38.5"s locked front/rear 97 reg cab ranger on 38.5s |
Tweet
#19 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Yeah saw that mounted them in the dark in my yard writing on the side is pretty small. I'll fix it later .
__________________
Tweet
#20 |
TOTM Coordinator
Year: 1992,1994,1995
Make: Ford,Ford,Jeep
Model: Ranger,Ranger,ZJ
Engine: 4.0l,3.0l (soon to be 302),5.2l
Class: 2wd Street
Used For: learning experiAnce, daily
Rep Power: 10 ![]() ![]() ![]() ![]() iTrader: (1)
cool build I don't know how I missed this
__________________
My build thread Cardomain '92 Ranger X-cab 4.0l '94 Ranger long bed 3.0l, bagged and chopped '95 Jeep Grand Cherokee 5.2l, wheeler someday '13 F-150 Ecoboost 4x4 daily driver www.lhinteriorsllc.com |
Tweet
#21 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Thanks for the compliment hoping getting it on tires will give me some motivation. Another bonus it will fit through my garage door with an inch to spare! Starting on the wiring tomorrow which is going to be my least fun part of the project.
__________________
Tweet
#22 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Talk about a long time coming the story of this tranny and its rebuild. Goes something like this bought at a swap meet took it to a guy to rebuild sat at his house for a year. So I went and got it and used it for mock up. Built tranny mounts installed dual cases etc. Took it to another guy to get it rebuilt 3weeks ago he say you know I think its a c5. So long story short lots of hours on the internet researching to try to figure out what I need to do.
So what Ive got is: c5 case 6 pinion planteary reverse manual valve body large tranny pan new torque converter tci 157 tooth flexplate 50oz Problem is now all my tranny mounts are 1/2 inch too far back because the bellhousing I used for mock up is a c5 and I have to use a c4 bellhousing. So Ive got some shit to do. ![]() ![]()
__________________
Tweet
#23 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
Finished a buddys prebent cage a,b,c pillars all prebent and welded together. I added the gussets and connected it to the frame.
__________________
Tweet
#24 |
Year: 1990
Make: ford
Model: ranger
Engine: 5.0
Class: 4x4 extreme
I got something done on my truck between rollcages and bumpers for friends.
Transmission and transfercases are in moved 1/2 inch forward cut all the mounts off and welded them back in. Now the tunnel in the truck is the fab project Im least happy with. Once it gets on the road my buddy whos a sheet metal worker might be repaying me a favor and helping me redo it. ![]() ![]() ![]() ![]() ![]() Heres the skid painted and in the front of it hangs down a little and is a little long. Im hoping I can get the exhaust ran right through here and run a tube from the front of this to the engine crossmember to protect the exhaust and oil pan. We will see might be getting changed. The front part of this crossmember is removable for transmission service ![]()
__________________
Tweet
| Bookmarks |
| Thread Tools | |
| Display Modes | |
