Home Ford Ranger Forum Builders Guide How To Tech Other Articles Featured Rangers Readers Rangers Classifieds Shirts & Decals
Old 01-16-2011, 02:18 PM   #1
newb23
Vehicle Year: 1997
Vehicle Make: Ford
Vehicle Model: Ranger
I use this vehicle for: Everything
newb23 is on a distinguished road
Default 97 2.3l heater problems
Ok, i cant get any heat in my truck, both hoses going into the heater core are getting hot, has plenty of coolant, and all i get is cold air. I haven't flushed the heater core cuz both hoses get hot, I have no clue what to do now, anyone get an idea?
newb23 is offline   Reply With Quote
Advertisement - Don't want to see the forum ads? Click HERE to find out how to be a Premium Member.
5% Rock Auto Discount Code: 83E98FB3D89C78 Expires: June 26, 2018
Old 01-17-2011, 05:54 AM   #2
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Vehicle Model: Ext Cab, 4WD, Auto, 4WABS, AC, 140k/90k.
modelageek will become famous soon enough
Default
Quote:
I dont know a lot about this part of the heating sytsem but it sound like it could be te blend door or maybe the controls. I think they work on vacuum. it sound like your t-stat and heater core , and heater control valve are fine. does the air come out of just the defrost or all of the positions? here is a site that has a way of fixing the blend door if that is your issue http://www.heatertreater.net/Ford%20Ranger%2093-08.htm
__________________
2004 Ext Cab, 4WD, 4.0, Auto, 153k(engine is out of a 2009 Ranger with 95k) Mileage readings as of 5/14/2017
2004 Ford Ranger Edge, Ext Cab, 2WD, 3.0, 5 speed, 116,000, AC. (SOLD)
1999 Ford Ranger, Reg Cab, 2.5, 5 speed, 2WD, no AC, 150k (SOLD)
modelageek is offline   Reply With Quote
Old 01-17-2011, 08:42 AM   #3
newb23
Vehicle Year: 1997
Vehicle Make: Ford
Default
i just replaced the t-stat and the temp control panel inside the truck, an all i can get in any position is the defrost. whats the best way to tell if its my heater core?
Old 01-17-2011, 09:59 AM   #4
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
Did you have the issue before changing the temp conytollor. It sounds like you have a vacuum leak. The default position for the Heater is Defrost.ie. If youhave no vacuum it goes to defrost
__________________
Old 01-17-2011, 10:51 AM   #5
modelageek
modelageek's Avatar
Vehicle Year: 2004
Vehicle Make: Ford
Default
do you have anyother vavuum related issues with your truck....
see if you can get "Big Jim M" o help you. he has helped other members with the same issue you are having
__________________
Old 01-23-2011, 08:57 AM   #6
newb23
Vehicle Year: 1997
Vehicle Make: Ford
Default
im thinkin i do, thanks for the help
Old 01-23-2011, 12:57 PM   #7
v8318cid
Vehicle Year: 2010
Vehicle Make: Ford
Vehicle Model: Ranger XLT
I use this vehicle for: Occasional DD
v8318cid is on a distinguished road
Default
If I'm following these threads correctly, the 97 model is famous for destroying the blend door actuator on the electronic models. If you have a factory non-a/c model, I've heard that they are cable-driven and aren't as prone to this particular problem. I believe there are pages on the Tech section that explain how to check and repair this problem if the door is to blame.
Otherwise, to check the heater core itself, simplest test is to check the tubes coming out of the firewall, if you haven't done so already. If both sides are roughly the same temperature (very warm to hot), your heater core is probably ok. As for your vent position selector, definitely check vacuum. The door is controlled by vacuum on all models as far as I'm aware. There should be a line set (vacuum hoses) attached to the back of the HVAC control head that you replaced. Check there to see if you have vacuum present. If not, check at the firewall. Might need a diagram from a service book or the VECI label under the hood to find out exactly which hose is which.
v8318cid is offline   Reply With Quote
Old 01-23-2011, 01:13 PM   #8
5.0
Vehicle Year: 1993
Vehicle Make: Ford
I use this vehicle for: Future daily driver
5.0 will become famous soon enough
Default
If the heater hoses both get hot where they go in to and leave the heater core, then your heater core is likely good.
If the air only comes out on defrost regardless of selector position, it's likely a vacuum leak. Check the vacuum hose under the hood to see if it's disconnected, leaking, or rubbed through. It's a small hose on the passenger side of the truck coming from the cab near the blower box. Also check for vacuum farther down the source if you have no vacuum on that line.
And v8318cid, my '97 factory non air truck was cable driven, so you have heard correctly.
5.0 is offline   Reply With Quote
Old 01-23-2011, 01:35 PM   #9
Ranger44
Ranger44's Avatar
Vehicle Year: 1995
Vehicle Make: FORD
Vehicle Model: Explorer
I use this vehicle for: Riding mad max style......
Ranger44 will become famous soon enough
Send a message via AIM to Ranger44
Default
Most definitely. You DO either have a vacuum leak or more likely a door/actuator problem.
Just the simple fact that it only operates the defrost supports this.
The simple should be checked first like stated previously. Check the main feed vacuum line to the dash. After that it's a tracing game, and checking for broken doors, rods, or failed vacuum actuators.
__________________
Some people are like mushrooms, ya gotta feed em' shit and keep them in the dark.
Giddywomp Offroad & Fab
Ranger44 is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
1999-2018 / 959 Media LLC / All Rights Reserved
