84 b2 tire gate
wildbill23c
TRS Banner 2012-2015
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
19K, 19D, 92Y, 88M, 91F....OIF-III (2004-2005)
Mine was missing the original attachment hardware so I just got a couple of carriage bolts long enough, ran them through then put on a washer and lock nut to hold them in place, then put the spare tire on and a couple more washers and lock nuts. However, at some point I'm going to see if I can find a bumper with the tire carrier on the bumper, I do not like that mounting system of these carriers on the body of the vehicle.
stegomon
20
auburn/minot maine
fords and only
I kind of figured it out. But I don't think it will work with my wheel...I see why the later ones was different
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
I don't like them at all, but putting the tire inside in the cargo area leaves the cargo area useless. kind of a tossup. Other idea would be getting a roof rack and mounting the tire up there...which is fine for stock size tires but for oversize heavy tires probably not the best solution.
I think I saw a bumper and tire carrier solution somewhere a while back that puts the spare on a swing out mount on a customer bumper rather than being attached to the side of the bronco 2 to cause damage. Not to mention the rattling noise as well from that mount.
stegomon
20
auburn/minot maine
fords and only
I have a bumper I want to use. Just not the skill. Lol. If it is bolt on I can do it.... Fabrication....nope
lil_Blue_Ford
6,122
Butler, PA, USSA
4.9L
I'm going to end up pulling the one off my choptop. Not sure what I'll do with it yet, but I do know that hauling around a 35 on it didn't work out so well. All that weight bobbing around and a little bit of rust started to do not so nice things to the body.
I picked up some steel awhile back with the idea of using it for a bumper with a swing out carrier, just haven't fully decided yet on how exactly I want to build it. I have some preferences in mind for my own bumper, but it would be easy to build one with a swing out carrier if someone wasn't too particular. Too bad you don't live closer, I could probably help you out with the fab work. Unless you want to road trip down here, lol
Sent from my kite using a trebuchet
bronco2fan
10
Copperas Cove, TX.
Engine Type
2.8 V6
2.8
2WD / 4WD
3 inch body lift
I have a 32 mounted on mine and it fits ok. I just reinforced all the mounting points with angle iron in the corners and plywood in the lift gate. So far so good. :derisive:
donaldcon
19
Lancaster, Oh
4.0
I run a 35 on mine
Sent from my SAMSUNG-SM-G891A using Tapatalk
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
I really like the Duff rear bumper. Now all I need is the money and the wife's approval :)
Scroll down to see the bumper:
http://www.jamesduff.com/newproducts/new_bronco2.asp
Thank you JerryC for the link. That is exactly what I was thinking of. That's a very nice carrier setup, and my bronco 2 doesn't have a trailer hitch so that would kill 2 birds with 1 stone. Yep, need the money as well LOL. Although not a bad price, but I'd have to find someone to paint it. I'd think for $600+ it would at least be painted but when there aren't any options out there I guess you can't be too picky.
wildbill23c
Ham Radio Operator
577
Southwestern Idaho
Engine Type
2.9 V6
2WD / 4WD
2WD
Total Drop
215/70-R14
There's also this one:
http://http://www.dufftuff.com/bronco_2_ii_plate_carrier_receiver_bumper_can_jack_p/4939.htm
That is a solid bumper instead of a tube bumper.
Duff seems to have two websites for some reason.
Hmm, well kind of a tossup now, I like them both LOL. May end up going with this one as it looks like its painted.
Either way I wouldn't complain about having either one of those bumpers. It fixes that terrible stock tire mount, and gives me a trailer hitch receiver. I don't plan on towing but its nice to have the receiver even if its to hold one of those hitch mounted racks.
JerryC
56
Tennessee
2.9
I agree, mine came with trailer hitch but I didn't plan to tow anything with it and took it off but put it back "just because you never know". The other day in the snow I realized i didn't have any tow hooks to use to pull a truck out of a ditch and thought that a ball mount with a D-ring would be a good thing to have. The problem with the hitch is that takes away ground clearance and is heavy.
The PO removed the carrier and latch from my BII, I don't have a spare at all and that bumper would solve a handful of things at one steep price :)
I'll keep dreaming and scheming...
Staff online
Shran
April Truck of The Month
