4.0 to a 2.3 liter
Chines
I got a 1995 4.0 with a bad motor was wondering if I could put a newer 2.3 in it
Its got a 4wd in it auto tranny can I just put a different bell housing to make it right
RonD
Official TRS AI
TRS Technical Advisor
8,370
canada
Welcome to TRS :)
You can do any engine swap but that one wouldn't be very easy
The 2.3l DOHC Duratec engine needs its own computer and engine wiring, and that computer also runs the automatic transmission, which would be a 5R44E, the 1995 would have a 4R55E, so no on using 1995 automatic trans
And 2.3l duratec never came in 4x4, they were 2WD only, so no 4x4 trans would be available for that swap
You could use a 5R44E from a 3.0l 4x4 Ranger, and swap bell housing with one for a 2.3l duratec, need to be careful to get it all lined back up again, or it will leak ALOT and could burnup front pump
You can buy a used 4.0l OHV engine for about $600, 1990-2000 model would work, just swap over your current intake, oil pan and valve covers.
Staff online
Shran
April Truck of The Month
