Ford Ranger 3.0L SHO swap
BryWink
Hello, i know that their are plenty of posts on this. but most of them ramble off topic. I found a good deal on a 1993 taurus SHO motor with everything to make it run. It came out of one with a bad transmission 71,000 miles. stored in a heated garage. What all do i need to know about this swap. pilot bushing the same on my m5od 5 speed trans? clutch? flywheel? clutch splines? i know the intake needs to be swapped around to be on the correct side. what about the a/c pump? power steering pump? alternator? will any of these be plug and play or do i need to use everything off my stock 3.0L motor? can i run my stock fuel pump? lastly i know the SHO motor has a much higher redline, what will i need to do to have the stock tach match correctly with the new motor?
tinman_72
136
North Georgia
Engine Type
2.5 (4 Cylinder)
2.5
2WD / 4WD
2WD
Factory
Total Drop
None
255/60R15
RoHS compliant
I don't have specifics but nothing will be plug and play. Pretty sure everything off your stock 3.0 will not fit. The Taurus 3.0 was manufactured by Yamaha and is a completely different motor than any other used by Ford.
fangotango306
8
sc michigan
ford
None yet
Someone used to sell a bell housing adapter to run a t5 but i cant remember where. There is also some issues with oiling on those when mounted longitudinally instead of transverse. Ive personally know a guy who used one in a sandrail running megasquirt for injection but that only lasted a while before he went to an ls motor.
BryWink
Okay, i can modify to make things work like the power steering and a/c pump, wiring i can do with some diagrams, but what about the clutch, i know the trans will swap over fine but is the clutch in any way the same?
BryWink
i think i will be fine for the most part on the stock trans as long as im not doing a bunch of hard launches, this isnt going to be a race track by no means. what is wrong with the oiling while they are mounted longitudinally? Mounted in this way does this bring the sump into the front? so the oil runs away from the sump? heads dont drain back into the bottom end? the biggest things im really worried about is the clutch setup, and now this oiling issue. really everything else i can make work.
don4331
1,346
Calgary, AB
Engine Type
V8
5.3
BryWink:
If you are sticking with the M5OD-R1, you shouldn't have any clutch issues* - the hydraulic Throw-out is integral to the transmission.
*The SHO uses more/less the same clutch disc as the 3.0 Vulcan so you might have to do a little mixing between the 2 setups but it should work.
3.0 bell housing for a T-5 is $800+ touch..
BryWink
BryWink:
Awesome thank you! Yeah the t-5 swap will be future after it gets some boost Put to it. This motor will be going in with all fresh gaskets, new clutch , flywheel, slave cylinder, and master cylinder, that’ll Atleast get it drivable while I save up for box sides, left fender, and a few interior bits. The truck will be also getting an 8.8 rear end with limited slip, to get rid of the stock 7.5” open diff it has. It does have the Dana 38 front differential so not to worried about that being a weak link.
pjtoledo
2,959
Toledo Ohio
Fords
3.0 2.3
get on shoforum.com search user "off road sho"
he has a sand buggy with a SHO motor, and knows someone who is putting one in a racing Ranger.
don4331
1,346
Calgary, AB
Engine Type
V8
5.3
A high reving/low torque motor wouldn't be my 1st choice for an engine swap into a 4x4.
Best gear it low (5.13s?); 7.5 wouldn't be in danger from a SHO motor.
And personally, I would stay with M5OD-R1. M5OD is stronger transmission than T-5 (doesn't shift as nice though), and bolts up to your transfer case. T-5 with transfer case outputs are rare and they need guts replaced to stand up to any significant amount of torque. 4x4 T-5 would be OK, for stock SHO, but not a blown one; and when you swap to Mustang gears, you lose alot of ratio - 4.03 or 3.76 1st to 3.35 or 2.95. M5OD plods along with 3.72:1 1st
BryWink
Awesome thanks, i will check that out.
BryWink
yeah i know the 7.5 is weak, we have had mustangs break them a lot, the SHO im deciding on for the amount of work needed for the 302 swap, will be more than im looking into, and i really hate the look of a body lift, i dont want to be able to see between the body and frame, plus figuring a supercharger kit ought to gain a lot of tourque in the future, not to worried about how it shifts, it shifts wicked hard now with the bad slave cylinder and ive gotten used to it. thank you for the response.
fangotango306
8
sc michigan
ford
None yet
I spoke with our family fried that had the rail and the oiling issue he explained was a drain back issue from the head. It wouldnt return fast enough and pool in the head/valve covers. He aslo told me it was really bad in the dunes climbing a hill at full throttle, but after enlarging the return holes it was mostly remedied. His buggy transaxle places the engine backwards too. May have something to do with it. He had nothing but positives to say about those engines though.
BryWink
So from what it sounds like, is that the front of the motor was to the back of the buggy, bringing the oil mostly to the front of the valve covers and heads, so not entirely postive as to where the drain passages are, but if the passages are in the rear, or towards the flywheel. that i could see causing an issue. so with the flywheel facing the rear of the vehicle, i should only see an issue on descending very steep hills? or because of it being at a low rpm while descending then it shouldnt have am issue?
thanks,
Bryant
85_Ranger4x4
Forum Staff Member
TRS Event Staff
OTOTM Winner
17,804
SW Iowa
Engine Type
V8
5.0
Honestly the 5.0 swap sounds like less work for what you get out of it to me... :dntknw:
A blower won't add a whole lot of low end torque.
fastpakr
Forum Staff Member
TRS Event Staff
2,832
Roanoke, VA
Engine Type
V8
5.0
2WD / 4WD
A positive displacement blower certainly should.
Staff online
Members online
Shran
April Truck of The Month
