Anyone ever heard this noise before?
AgPete139
09/2014 OTOTM Winner
61
Houston, TX
4.0L OHV
Solid Axle Swap 4x4
~9"
35"x12.50"x17"
New TRS members can be so unappreciative. Just in general.
Ugh, today is one of those days I need to walk away from here.
/rant off
92danger
I never said I didnt appreciate the advice. I do. Very much so. I was just curious. Thank you everyone
92danger
Well ill be getting a new cat-back exhaust system sometime this week. I really do appreciate and care for our environment despite what others think. Just so ya know my cig butts and gum wrappers go in my pocket til I fi d a trash can. Anyway maybe that will help the problem. Also, its recently started idling rough. More so before its warmed up. Ill be doing a few tests on that in the morning (iac unplug, wot cranking, etc.) I believe the truck only has 185xxx original miles on it because when I replaced the clutch and cylinder (less than 1k miles ago) it still had the factory glued-down sound deadening foam AND the clutch had the raised ford logo stamped on it. Still breaking in right?
FYI so far ive replaced:
Radiator
Timing belt
7 plugs 8 wires (COULD NOT FOR THE LIFE OF ME get the new plug to thread into DS#1. Cleaned and regapped the old plug)
ICM
Fuel pump & filter
Front & rear brakes (EVERYTHING but the calipers and the lines)
Clutch & clutch cylinder
Air filter/oil/new tires/refilled trans fluid (was damn near dry) routine maintenance
I think thats it. Worked on it so much I cant really remember
OH YEAH! Replaced the bumper ;)
Any input on anything will definitely be read and much appreciated. Goodnight all
