Front and rear sway bars on my 90 Bronco II
jayterrence
Ok, I am here to ask the guys that know all..... I am about to install a 4 inch BDS lift kit, I have the super saggy rear springs, so i am installing a new set of leafs from a Ford Exploder, re-arched and the BDS add-a-leaf installed. This is going to make the rear very stiff, as well it will add about 1.5" of lift even before I install the lift so there are concerns about the front end height matching the rear. This is to be an off road vehicle. I want to remove the sway bars in the rear, with the extra stiff springs i don't think i will need them since i am primarily off road. Now I have been reading about others who have removed both front and rear sway bar links. For my application, does it make sense to remove them??
I am looking for some good feedback and possibly any issues I may run into along the way, the truck will be in the shop next week. Thank you.
CurtisP87
Portland, OR
2.9
I think most people who primarily offroad their trucks would say to remove both sway bars. I removed my rear bar, and made some quick disconnects for the front. I drive my truck to the trails, so having the front bar on for the highway gives me a little peace of mind, and it only takes a couple minutes to disconnect when we hit the trails. Having them off isnt a huge deal, as long as you know how to drive safely on the highway. No sway bars will give you a bit more body roll in the corners, so just remember youre in a lifted truck, not a sports car; watch your speed going into the corners and youll be fine.
Today's birthdays
Shran
April Truck of The Month
