1989 Ranger
ptofimpact
Coastal NC
2.9 l
Preparing to remove factory radio, have the removal Tool, and know how the Dash Bezel comes off, just need help with Headlight Knob, how to take off??
ericbphoto
Overlander in development
TRS Event Staff
GMRS Radio License
16,592
Wellford, SC
Engine Type
3.0 V6
3.0L
2WD / 4WD
6"
35"
In theory, theory and practice are the same. In practice, they are different.
If I recall correctly, there is a little spring clip that holds the knob on. If you can get something to get in behind the knob and depress the spring, it will come off easily.
Usually, if you pull hard enough, the knob will come off and leave the clip behind. Then you can just poke the clip back into the knob and push it all onto the shaft for reinstallation. I've done it that way a few times and never had a loose knob. But it's possible that it would start to loosen up after a while and not stay on. It's a lot easier to understand once you see it apart.
Eric B
scotts90ranger
RBV's on Boost
4,366
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
The headlight knob doesn't need to come off to get the bezel off... it's on it's own bracket that's screwed to the dash. For the dash surround to come out, take the two ashtray screws out (7mm if memory serves... I don't have either screw holding mine in...) then remove ash tray, it just pulls out with a fairly strong detent in the back. From there just pry outward as there's like 6 spring clips holding the rest in, pretty simple, I've had mine out dozens of times over the last 19 years...
Terry
19
Gardnerville, Nevada
2.9
Actually I believe that there is a screw behind the strip where the headlight knob is. You don't need to remove the knob. If you pull the switch out "turn on the headlights", you can pull the clips out far enough to turn the strip and you will see the screw you need to remove.Don't leave the headlight switch on when you are done.
scotts90ranger
RBV's on Boost
4,366
Dayton Oregon
Engine Type
2.3 (4 Cylinder)
2.3 Turbo
2WD / 4WD
35"
I haven't taken the headlight knob off since '99 when it broke in half and I super glued it back together and it's had two stereo's since then and a different instrument cluster along with screwing with the boost gauge where the 4x4 buttons would be... My Ranger is a base model though, it doesn't have the fancy surround with fake wood grain or anything, I added the cubby under the headlight switch from a junkyard find...
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
If I remember right, there’s a push button on the headlight switch body that releases the knob, it will actually kinda eject it. I ran into the problem with my choptop that the roll cage is too close to the dash to get the spring clips out for the panel, lol
Sent from my kite using a trebuchet
Staff online
Today's birthdays
Shran
April Truck of The Month
