Engine Temp and Fuel Trims
So I've installed the cleaned injectors, fuel trims are more even. Unfortunately my battery crapped out while the truck was sitting for two weeks. That wiped out my computer memory and I had to start over again on fuel trims.
I cleaned the tar like crud as noted in the previous post with carb cleaner and Q-tips. After assembly I did a test drive then hooked up a vac line to the intake plenum with a small on/off valve. I cracked the valve just a little and bubbled in CRC Motor cleaner which is supposed to dissolve those deposits. I only dipped the vac tube in the cleaner very briefly so as not to risk too much liquid at once and allowed each injection to clear through. Used about 6-8 ounces.
Of course that gave me a P0300 pending code that cleared and I drove the truck a while to flush through the cleaner as I was getting very rich negative fuel trims.
Idle fuel trims went to BNK1 - -7.0 and BNK2 - -4.7. I thought maybe there was solvent in the oil as to the higher trims. I did an oil change and now have the trims at -1.6 on both banks, but have noticed a -3.1 and -2.3 BNK1 & 2 respectively, so I may need some more running in and computer learning.
Idle smoothness did not improve, to my disappointment, but idle fuel trims are better and more balanced. Without feedback on others fuel trims it's hard to know what's normal.
As I discuss in the PCV thread:
http://www.therangerstation.com/forums/showthread.php?t=161366
I don't think oil vapors are a problem on this engine with fuel trims. I think the accumulation of oil in the intake is normal over the 78k miles I have on the truck. I will however do a once per year intake flush as described above, but only just before I need to do an oil change.
Truck is running great with no noticeable issues except for a little lumpy idle I'd like to fix, but don't know where to go.
Trouble with a scan gauge is - it can drive you nuts. I'm closing down the fuel trim page for the gas mileage page for a while. Switching to Shell gas to see if mileage improves.
