Shaking on freeway with upgraded rims
Dfoster93
Bay Area, CA
V6 3.0L
Over the weekend I replaced my stock rims with aftermarket black steel rims that I got from a friend. The stock rims were 5 lug 15x7 with a 5x4.5 bolt pattern. And were replaced by 15x8-8.5 5 lug. I had them put on by a small mom and pop shop and the tires were also balanced. Everything felt fine until I got on the freeway going above 50mph and there was terrible shaking in the whole truck. If I'm driving below 50mph there is no issue at all.
I'm not sure if the balancing was done improperly or if the truck needs an alignment. I have no idea what could cause this. There was no issues with the steering or shaking prior to putting on these new black steel rims.
Mickey Bitsko
Pagosa Springs CO>
live everyday like your gonna die tomorrow
I had the same problem on a toyota p/u long time ago , with brand new out the box aftermarket rims , two of the four were welded improperly and caused them to wobble, didn't notice any problem on surface streets but above 50mph terrible, had a buddy follow behind saw the problem. The company fought with me , accused me of abuse, but finally settled getting most of my money back
[ had to pay freight]
racsan
4,441
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
i have that issue with my steel 15x8 bart wheels black "D"-window wheels. 1 has a huge amount of balance weight on it, i actually had them balanced twice. been living with it, when the tires are shot im just going to go back to my stock alloy rims and use this set to put on something headed for the junkyard. they even have more offset than what i was told they were. supposed to be a 4" backspace and they are 3-1/4" has a nice deep-dish look, almost looks like 15x10's. ive since read that alot of wheels mfg by bart wheels have a balance problem, they are made from really thick steel, so they are heavy. would be ok for off-road use but not so good for a daily driver or for long highway trips. i doubt there is a "fix" besides another set of rims.
