Wire Mystery
RjE
Mazda
4.0L V6
94 Mazda B4000
4.0 Liter V6
Manual 5 Speed
4x4 w/ RABS only
Hey Team,
I was checking under the hood and noticed a grounding terminal that had no wire attached. Looked around and found two broken pieces of wire, one is red and the other is black w/ green stripe. This was on the driver's side front fender well. I looked down at the wiring harness and finally saw the two broken ends, so I spliced in a temporary connection from the broken ends to the grounding terminal. After starting the truck I checked everything, but didn't notice any changes.
So--what do these wires go to? I checked the wiring diagram in the Haynes Manual but called no joy.
Pictures are attached--hope they help.
alwaysFlOoReD
5,090
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
bump for knowledge
zer03Four
Mazda
Man ive been trying to find some decent wiring prints for the mazda but no luck. I couldnt tell ya what those wires do, but generally red is POS and black/green would be NEG so i wouldnt recommend putting the RED to chassi ground. I would just leave them disconnected until you can figure out exactly what it is. If you find some decent wiring prints let me know. ill do the same.
