88 2.3L Stalls after cold start and hard when warm.
katoranger
Altamont, KS
Toyota
1.8
I just bought an 88 ranger with a 2.3L and 5spd. Truck runs great, but when the engine is cold and go to start it with start just fine idle up to about 1800 rpm the drop to about a 1000 and then down to about 500 and stall. Usually have to start it 2-3 times before it is ready to go and then it is just fine. The idle speed after engine is warmed up is about 1250 rpm.
After it is warm and stop someplace for a short period of time it starts alittle hard. It somewhat sputters to life and then smooths out and idles just fine.
What I have done. New motorcraft plugs and wires. New cap and rotor. New fuel and air filters. I cleaned the IAC out, but didn't seem to help much. Thinking it may just be bad. Haven't tried disconnecting it to see if idle changes.
Truck also seems to lack power, but that may be just the way it is.
Allen
katoranger
Altamont, KS
Toyota
1.8
Would a leaking injector possibly cause these symptons?
I pulled the connector off the IAC and it changed the idle. Did the same with the map sensor. Same results. So it seems that these are probably working. It likes to warm up first before going down the road too.
It runs fine once it is up to operating temp. No hesistation or bogging.
Allen
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
