Superlift or SAS?
Fiveflat
Sacramento, CA
I just picked up a B2 to use around my property. Now that I have it, I'd like to make it kinda trail ready as well. I *THINK* I want to do a full width SAS but I don't know enough about them yet. I want to lift it asap though and I was looking at the 4.5" Superlift for it.
If I go the SAS route AFTER the superlift, will I end up with a take off lift kit? Or will parts from the kit be used for the SAS?
The superlift kit is $631. What should a fw-SAS run me complete?
Fiveflat
Sacramento, CA
I wish I knew more about what kind of labor is involved in a SAS. I just found this on craigslist for $600:
The whole package Dana 44 and 9" with everything you see on them:
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
I think the question should be:
"Full-size-width or Stock width?"
If you want it to be full width, then a SAS using that stuff would get you there... Another option might also be to use a FW D44 TTB ('80-'96 trucks), which this would allow you to reuse a majority of the parts from a lift for the stock suspension.
Superlift is among the last choices I'd pick for a lift on yours though. Skyjacker or James Duff have far better quality products.
What are your intentions? Rock crawling? Mud-whomping? Speed running? (desert, sand, etc.)? Trail driving? (trails in the forest, powerline/mining roads, etc.)?
Also, and welcome to TRS :beer:
Fiveflat
Sacramento, CA
Skyjacker only offers a 1.5" or a 6" lift. I don't want to go 6" high. The James Duff kit is only 3" and the Superlift is 4.5"
I was chatting with another friend of mine and it seems the best process might be to simply put a small lift on it now (all I really want are 31's maybe 32's). And upgrade to an SAS as things break if I need to. I called a local shop that does SAS turnkey and I about choked on their quote... I can't justify 10TIMES what I paid for the entire truck on suspension alone. Not at this point anyway. :)
Fiveflat
Sacramento, CA
by the way, yes a full-size-width is absolutely the route I'd go if I decide on an SAS.
Perhaps the turnkey shop's quote needs to pay his mortgage and health insurance so that's why it was so high? I was quoted around $7000-8000 (hence my choking on thin air)
I am a mechanical guy but I just don't know what is physically involved in the swap.
Fiveflat
Sacramento, CA
Thanks for that link! much appreciated.
4x4junkie
Forum Staff Member
583
So. Calif (SFV)
Bronco II
Engine Type
2.9 V6
2.9L V6
2WD / 4WD
35x12.50R15
Skyjacker has 1.5", 4", 6" and 8" lifts.
Sounds like the shop quoted you a price as if they were going to SAS an A-arm IFS truck, not a TTB truck (it's about 1/2-2/3 the labor on a TTB truck since a lot of the hardware can be reused (steering box, coil mounts, etc).
armadillon
12
Austin, TX
3.0L
Hmmm. Fullwidth sounds cool. I wish I had a full-width ranger. That moved.
Fiveflat
Sacramento, CA
I think a full size TTB is the direction I want to go for my needs. Still have no clue whats involved in that swap, but thats why I'm here I suppose. What's all your opinions on that?
What I want is a good trail rig and be able to make runs across some flat dry ground at speed...
country0001
14
Stillwater, OK
Ford,Ford
4.0,5.0
Check out desert rangers or something like that and search out a guy named Joel. He makes a kit to make it a bolt in
Today's birthdays
Shran
April Truck of The Month
