Two issues on one thread lol
tjs4x4
2
ID
4.0L
First issue: RUST! YES, RUST! On the rear 'side panels', whatever the heck they're called. AND, yes, I said AND, rust on the tops of the rear wheels wells. What is the best way around this? This rust is eating away at the back end of my Ex.
PIX: LEFT SIDE:
Right side is starting to rust out just like the left, only not quite as bad.
SECOND:
The rear gate doesn't seem to be aligned right, and its very hard to open. Also, stupid question, shouldn't there be a latch on the bottom of the gate too?
PIX:
voodoochylde
Rainelle, WV
2.9l
If it's anything like the Bronco II's you could have a LOT of rust hiding in the rear cargo area underneath the carpet. This can weaken the rear structure enough to make the hatch hard or impossible to open/close.
I HATE dealing with rust so I don't do much of it. I've been known to "build" partial fenders/quarter panels with expanding foam, bondo, and paint. That was, obviously, ONLY to pass inspection.
I reckon the right way to take care of it is to cut/grind ALL of the rust out and reweld good metal back in. Cover with your choice of paint.
Good luck!
tjs4x4
2
ID
4.0L
I've pulled the carpet up just to see what was under there, and there's not any rust there, yet. For which I am thankful the rust so far is limited to these areas.
How hard is it to spot weld? What all is involved, I want to learn so that I can fix this myself.
I plan on pulling that nasty carpet out of the rear anyways and lining it with vinyl. Guess its a good thing I took a peek!
voodoochylde
Rainelle, WV
2.9l
As far as spot welding goes, I don't know from experience. I do know that body guys will often weld one spot and then move as far away as they can until the original spot has cooled. Adding too much heat to your thin sheet metal will cause distortion in a hurry. Google should be a big help here. Maybe you can do an apprenticeship with a body shop?
Glad to hear your cargo area isn't a rust pit. I'd check the strikers and latches first. Check for alignment on both sides and make sure the latches are free-moving and well lubricated. In my experience, a product usually used for guns works great here. It's called BreakFree CLP and contains some minor solvents (be careful around paint you care about) and teflon. The solvents act as a carrier for the teflon and, when dry, leave a nice slick layer of DuPont's best accident.
The other place I would look would be the hinges. Again, check for alignment and proper lubrication. This isn't as critical as the latches as even stiff grease will work.
tjs4x4
2
ID
4.0L
LOL, I dunno if anyone would want a 'girl' in their shop! I actually thought about going into auto mechanics instead of nursing because I was a nurses aide for 11 years, and was totally tired of it. Alas, I did what I knew I could do. I'd love to learn auto mechanics tho. I may end up having to take it to a shop if I cannot find someone local to help me with this job.
Bennybooster
EMT / Paramedic
37
Medford, Oregon.
3.0
There are also community classes in most towns at the local college to learn welding and other automotive skills
tjs4x4
2
ID
4.0L
Good idea! I'll check the local community college.
I lubed up the latches/catches and it seems to be opening easier. I was having to use both hands to open it with the handle lol. Now I can open it with one hand on the handle. Maybe its just cuz the rig is old that it doesn't seem aligned LOL.
Soo, what IS that circled hole for? LMAO!
Nathan123
2
Millersburg Pennsylvania
2.9 Litre
I would imagine the round hole is to put the handle of your jack in to crank down the spare tire. I believe there should be a cheesy lock on it so it's inconvenient to steal.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
+1 The hole is for the crank hole to lower the spare tire. The crank handle should be located under the hood clipped to the radiator support. My Ex never had a lock on it. My Ranger didn't come with a lock either.
tjs4x4
2
ID
4.0L
I was actually thinking about just replacing the whole panel. Anyone know where I can find those pieces, and the metal for the top of the rear wheel wells?
voodoochylde
Rainelle, WV
2.9l
LMC or scour the junkyards if you want the closest fit.
tjs4x4
2
ID
4.0L
What is LMC? Do they have a website? I don't want to go to the junkyards for the rust repair :)
tjs4x4
2
ID
4.0L
Staff online
Members online
Today's birthdays
Shran
April Truck of The Month
